Is This Turbo Any Good For The 3.4L DOHC??
  • grandprixgtp_91
    • Nov 2003
    • 758
    Hi, im finally gonna start my project to boost my 3.4L DOHC, now im looking at some turbos and I finally found one I think I want, but since I dont know much about turbos I want you guys professional opinon. Heres what im looking at :
    - Turbonetics 62-1 Turbocharger
    - Dry Center
    - .96 A/R On Center
    - T4 Turbine
    - 360 Degree thrust bearing
    - 4.00" Inlet
    - 2.50" Outlet
    - VSR Balanced
    - Supports 60LBS/Min Or 600 HP
    - 3.5L - 7.5L Engine range
    - Perfect for most 8 cylinders
    so thats what im looking at, I dont really know what alot of the specs mean, but I know that the 3.4L DOHC needs alot more air flow than a regular v-6 which is why im looking at this turbo. do you guys think it will work good? please let me know I plan on buying it in the next day so a fast response would be awesome! thanks
    Jake
  • MidnightriderZ24
    • Jan 2005
    • 699
    .96 on the exhaust will be a little bit laggy, but that thing will make some power on a dohc FOR SURE!
    [SIGPIC]
    12.268@117... 11's to come!
    • grandprixgtp_91
      • Nov 2003
      • 758
      Ok, I bought it, hopefully it will be good , thanks for the response, anyone else wants to cut in and give there input please do, i want as much responses as possible so i know what to do.
      Thanks
      Jake
      • 34blazer
        • Sep 2007
        • 341
        maybe you should look into getting a smaller turbine housing, like .82 a/r. this will help keep spool up a little lower in the rpm range
        '86 Grand National
        • grandprixgtp_91
          • Nov 2003
          • 758
          what do you guys thinks this thing will spool up at ? i do have a 5 speed so i dont really want it to spool at really low rpms because it already spins the tires like crazy on a launch so im probably gonna have to get some big drag radials for racing.
          Jake
          • grandprixgtp_91
            • Nov 2003
            • 758
            Ok i contacted the company that i got the turbo from, they havent shipped it yet and they have .81 a/r and .68 a/r so i told them to get me a .81 so hopefully that should help.
            Jake
            • MidnightriderZ24
              • Jan 2005
              • 699
              either way when it does spool it will come in hard. thats a great choice of a turbo. i had a .82 t70 and it spooled around 3500 and it came in HARD. that compressor flows plenty for the dohc.
              [SIGPIC]
              • timg
                • Feb 2004
                • 718
                That's definitely a big turbo for the DOHC, but it should work great (especially if you're shooting for over 400 whp).
                tim
                325 whp 350 lb-ft
                • grandprixgtp_91
                  • Nov 2003
                  • 758
                  Ok, i got the turbo the other day, finally came in, and they sent me a .68 a/r housing on it. is this to small for the dohc? thanks
                  Jake
                  • Matt Hawkins
                    • Jul 2007
                    • 20
                    That A/R will be fine. That is a big turbo for your engine. What is your HP target? I am running 415 WHP with a Garrett GT3071R. It is a much smaller turbo and I am running a 0.63 ATP turbo housing.
                    1987 Fiero GT - 95' 3.4l DOHC LQ1, GT3071r turbo, intercooled, Haltech E6K, custom stainless headers and exhaust, Tial 38mm wastegate, 38 lb/hr MSD injectors, custom intake manifold, 12" 4-piston front brakes, 11.25" rear.
                    415 WHP, 11.92 @118 1/4, 28 MPG, on pump gas.
                    • reven565
                      • Feb 2008
                      • 12
                      HELP!!!
                      hey ive got a 93 lumina z34 and i was wondering does anyone have anytips on were to buy or even find turbos for a 3.4l engine.also i would like to know if there are any other upgrades to recieve a significant amout of hp. i appretiate any feedback, thanks.
                      • grandprixgtp_91
                        • Nov 2003
                        • 758
                        i was hoping for 400 whp , but the more i think about it i doubt i will get it, i have 42 lb/hr ford racing injectors, the turbonetics 62-1 turbo, turbonetics evolution wastegate, turbonetics raptor blow off valve and a 22" long 3" wide same side intercooler.
                        but i dont want to run any more than 9 psi, i have been advised its not really safe to run any more than 7 psi on a stock motor, because its my daily driver.
                        but i think 9psi would be ok with the intercooler, but i think to achieve 400whp at 9psi is dreaming,
                        so i guess as long as i get about 350whp i would be happy.
                        Jake
                        • grandprixgtp_91
                          • Nov 2003
                          • 758
                          ok i just contacted turbonetics with the serial number off of the turbo and they say it has a .58 a/r exhaust housing on it. so i went and looked at the stamp in the casting and to me it looks like it says 68 but i guess turbonetics would know better, i guess if you look at it the right way you could make the 6 look like a 5 but honestly if you just look at it you would swear it said 68 .
                          so now my question is is a .58 a/r exhaust housing to small? heres what turbonetics gave me for specs:
                          p/n 11006 non bb 62-1 Stage V tang undivided 58 a/r
                          Basically means:
                          Compressor: 62-1
                          Turbine: T3 Stage 5
                          Turbine housing: Tangential undivided housing .58 A/R
                          Center Section: Non-Ceramic Ball Bearing
                          i hope this housing isnt to small, this turbo already cost ALOT lol i dont want to have to go buy another housing for it.
                          Jake
                          • timg
                            • Feb 2004
                            • 718
                            It should be fine. My suggestion is to try it. If you don't like it, you can always swap it out.
                            Tim
                            325 whp 350 lb-ft
