another turbo hyrbrid build
  • Mr_Efficiency
    • Jan 2008
    • 197
    I have a 90 Grand prix with the 3.1. I'm doing a 5 speed swap the first weekend of febuary (getrag 284) and then I'm going to start tearing the motor apart probly end of febuary when i have all my parts together as i am still missing a few important items, anyways heres what i'm planning for a build.
    My bottom end plans are bone stock rebuilt 3.1
    For the top end I have the complete top end from a 95 3100, I know its not the best of the gen 3 top ends but it was cheap and I dont need custom length pushrods.
    The crossover and everything turbo related is custom.
    For management I'm using a TGP chip, 2 bar map sensor and I'm still undecided on injectors.
    Now that you have an idea of what i'm dealing with i have a few questions.
    Are the rings from a TGP diffrent from a NA 3.1? if so, I can use them in my 3.1 correct?
    How much boost is the stock 3.1 bottom end good for?
    What size injectors would be best for around 7 psi of boost? I know stock TGP's are 22lbs, would these be ok or should i go a little bigger?
    and finnaly, what kind of numbers can i expect from this? I'm a little worried about my clutch, whats it good till?
    Sorry so many questions all at once, I'm a bit of a noob to the 60* v6, i'm more of a quad 4 guy but thats a diffrent car, lol
    thanks in advance
    Mr_Efficiency
    90 Grand prix - Lawn ornament
    Black, 3.1, 5 speed
    Future holds: Striped and then scrap yard
    97 Cavalier - Stock car
    Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
    Future holds: Just more trophies
    New project on the way: 88 S10 reg cab, short box, 5 speed.
    Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
    With a gen3 top end, you'll flow more even before boost, so take that into account. You might max out the 22lbs with the gen3 top end and boost... But I don't know for sure.
    Bottom should handle 7psi no problem as long as your tune is good. Any higher than 9-10psi I would start worrying about pistons.
    #'s here is a guess with 7 psi and 3100 top end, over 200 somewhere... LOL
    • Mr_Efficiency
      • Jan 2008
      • 197
      9 psi was the highest i was thinking of pushing it, I'm not looking for any huge hp, just putting together what I've come acrossed cheap and putting it together for fun and a little more power over stock, thats why im sticking with the stock bottom end, i'm not looking at spending top dollar on this motor, just a basic rebuild cause it has 377XXX km/s on it and i wouldnt really trust it for boost, lol
      injectors are my only real concern, do you think I should upgrade to something like 30lbs or is that a bit much?
      what are the stock 95 3100 injectors?
      Mr_Efficiency
      Black, 3.1, 5 speed
      • Mr_Efficiency
        • Jan 2008
        • 197
        If i go with a 2.8 could i stick with the TGP injectors, since i'd be needing less fuel than a 3.1
        Mr_Efficiency
        Black, 3.1, 5 speed
