water injection?
  • Mr_Efficiency
    • Jan 2008
    • 197
    water injection?
    I want to run a water injection set up on my Grand prix but I cant find anything on how to make one. I'm mostly just concerned about how its injected, the rest is easy.
    can anyone help me out?
    also i was reading that its better to use windshiled washer fluid instead of water cause it has methanol in it, so I might just tap into the side of my washer fluid jug, lol
    thanks
    Mr_Efficiency
    90 Grand prix - Lawn ornament
    Black, 3.1, 5 speed
    Future holds: Striped and then scrap yard
    97 Cavalier - Stock car
    Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
    Future holds: Just more trophies
    New project on the way: 88 S10 reg cab, short box, 5 speed.
    Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
  • Joseph Upson
    Ebay usually has an economy kit for under $200 that would be a better option than building one.
    • powerdoctor
      • Apr 2008
      • 133
      Heres a link for water injection...
      http://www.jegs.com/webapp/wcs/store...ater+injection
      Hope this helps out...
      !!!!! BOSCH PLUGS RULE !!!!!
      http://www.cardomain.com/id/powerdoctor
      • 93grandprix
        1995 Cutlass Ciera 3100
        • Apr 2008
        • 21
        i have never heard of water injection. i know this will sound stupid, but i thought water will seize an engine?
        • GutlessSupreme
          • Nov 2004
          • 166
          Well if you try to make your pistons learn how to swim, then yes water will seize an engine. Water injection sprays a small amount of water into the intake to help cool cylinder temps and help reduce knock.
          -Tony | gtsdurango.net
          '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
          '90 Turbo Grand Prix STE - ehh.. I'm working on it.
          '92 Gutless Supreme SL - RIP 5.2010
          '90 Turbo Grand Prix - RIP 6.15.2005
          • 93grandprix
            • Apr 2008
            • 21
            oh ok, makes sense. thank you
            • loner666
              • Oct 2006
              • 435
              DevilsOwn has a kit for $200. Includes everything you need but a tank as they assume your going to use your washer tank unless you buy a separete tank. I have a kit sitting here to install on my car but its looking like its gonna be a LONG while before it goes on, if ever
              and yes washer fluid works wonders for this kind of thing.
              Methanol Injection, Alcohol Injection, Water Injection, DevilsOwn
              Best 1/4mile ET - 12.9
              Best 1/4mile MPH - 111
              1997 Ford Ranger Splash
              Daily Driver
              • Canyonero
                Plays with Volvos now.
                • Sep 2006
                • 1112
                :P
                • 93grandprix
                  • Apr 2008
                  • 21
                  now that link seems like a scam to me, just like that tornado air intake lol. but i do understand how water injection works now.
                  does it really improve performance signifigantly though?
                  • Joseph Upson
                    I didn't get to deep in that article, Rachels legs got in the way. One things for sure, if it sounds to good to be true, it is.
                    Water injection will only help you if there is a need for it, such as in boarderline high compression engines on the brink of detonation which it would be a bad solution for since the situation is permanent requiring appropriate fuel type instead and more practically turbocharging for added safety when you want to increase boost pressure on an engine to a level that would be dangerously close to the detonation zone or actually in it.
                    So it doesn't increase power itself, it facilitates the changes that increase power but also come with a detonation risk.
                    • loner666
                      • Oct 2006
                      • 435
                      If using methanol there will be a slight power increase from what I hear. The main advantage as said is to help prevent detonation which in turn allow more boost/timing to be ran thus making more power. I know I bought mine for the added safety to help keep the cyl. cools, especially #s 5 and 6
                      Daily Driver
                        Live life 3.7mi at a time
                        • 4555
                        Cheap water/meth injection...
                        have a look .. i was sucking out of a ara sol can cap it was full of washer fluid. takes less than 30 sec to suck it dry using this vacuum. this would be installed in the air duct before the throttle plate and it would just sit in it ( maybe i will tap a hole so it could be bolted in ) and...
                        • Mr_Efficiency
                          • Jan 2008
                          • 197
                          thats an interesting link but it dosent help me out much since im running an intercooler.
                          I'm mostly just wanting to know what people use to inject the water into the intake manifold. is it and injector kind of deal like a fuel injector or what? I was thinking of just a nossle like in the link above but my manifold is under boost so that wouldnt work out at all, lol
                          Mr_Efficiency
                          Black, 3.1, 5 speed
                            As mentioned in that thread if you run a line to the feed bottle to keep it presurized the same as the intake, it should still function.
                            • Joseph Upson
                              That's a pretty creative design in the video but I believe it's a bit risky considering water/meth injection gives you a good bit of boost increase without detonation so much so that if for some reason the mist doesn't flow under boost you are sure to see severe enough detonation to possibly damage the engine before you can get off the accelerator pedal.
                              Attached is a good read on water injection as well as the different mixes and associated temp drops. Stock Buick Regals were running boost in the 20-22 psi range using water/meth injection where they would otherwise have detonation around 14 psi so it's very effective.
