Hey guys I did a 02' 3400 swap into my cavalier about 2 months ago and want to go turbo with it as well. Im not very familiar with the injectors in those motors. What are my options for bigger injectors such as 36lb?
Fuel Injector Options
Using a GM stock injector (non aftermarket) ; You can go with, 22, 24, 28, 36, and there might be one more a little bit larger. It will be pretty much based on the power output and the tune efficiency that you'll have that will determine on what you need. Anything you do end up selecting WILL REQUIRE to be tuned for. It's not just a slap in and go ordeal. hth
PS I do have a set of 24 and 28 multec 1 style injectors. http://60degreev6.com/forum/showthread.php?t=39720Lifting my front wheels, one jack at a time.
