i found it !!!!!!!!
  • candychevy87
    anthony
    • Jun 2008
    • 76
    i found it !!!!!!!!
    Turbo header kit for turbocharging the 2.8L and 3.1L V6 Chevy engines and a direct fit on GM 3rd gen F-Body 1982-92 Camaro, Trans Am and Firebirds with serpentine belt powered accessories with A/C.
    The kit includes one passenger’s side all steel high quality header with Laser cut 3/8" thick steel flanges, external wastegate port flange and 1/8" wall thick pipes. Designed for use with a full size TO3 or TO3/TO4 hybrid style turbocharger.
    Some modifications are necessary.
    Part# TH0005
    Price: $350.00
    • 9179
    So they run the turbo only off of one bank (passenger side)? $350 seems kind of high to me for just a single header...
      Live life 3.7mi at a time
      • 4555
      No, it's the BBS headers. IIRC it uses the stock driver's manifold and uses the y-pipe as a x over to the new header.
      Yeah, $350 is high for one header. He makes them from 14ga steel.
      • candychevy87
        anthony
        • Jun 2008
        • 76
        regardless, it makes turbocharging alot easier for me, i dont have the time to fab up my own header, and my blazer is my only truck for now, i allready have the turbo so its not to bad, im not going to intercool right away.
        • FlyNLo17
          • Mar 2008
          • 8
          I turbocharged my 85 s-10 2.8L. I used a set of tubular stock manifolds from a fiero 2.8 They exit out the front of the engine, then I connected them together and mounted the turbo to it. Heck of a lot cheaper than $350. might want to look into that.
          • candychevy87
            anthony
            • Jun 2008
            • 76
            that is what i ended up doing, so far its coming along allright, i need to get my hands on a different cam now, i plan on using 8 to 10 pounds, my 3.4 is fully ported so itll kick its own ass soon enough
            • Joseph Upson
              They put the MAF sensor in front of the turbo instead of between it and the throttlebody, I believe it is more accurate measuring the condition of the actual air that is going into the engine since there is a burnoff wire in the sensor that I believe is used for determining air density by the rate it is cooled by the passing air especially if the turbo outlet air is over 200 degrees such as in my situation.
              It's a nice option for V6 owners and with a good size intercooler you could surprise a few. Now days some mini vans are closing in on 6 second 0-60 times and not long ago that was considered impressive. Now impressive is under 5 seconds 0-60 and under 13 in the quarter.
              • CobraCDR
                • Apr 2005
                • 272
                all saabs have a single bank turbo setup, it is not ideal but it works for a quick splash of power.
                2004 Black Cobra Vert
                New Best Time 9-2-07: 1.81 60' 12.06 @ 117.3 Mph
                455 rwhp/ 458 rwtq
                1988 Pontiac Grand Prix SE - New Setup: Stock 3400 with 52 k on it from a 05 Impala, 255 walbro, LC-1 WB, Spec 3 Clutch, CS144 Alternator upgrade, DIY tune
                1989 Pontiac Turbo Grand prix - 44 k original miles, birchtrax'ed & intrax'ed, crane 2020, Topgun 160 +++ my own special herbs and spices
                • timg
                  • Feb 2004
                  • 718
                  Their new ones don't. Single turbo fed by both banks on the 2.8l V6.
                  Tim
                  325 whp 350 lb-ft
                  • CobraCDR
                    • Apr 2005
                    • 272
                    ok well whatever the one I saw in the junk yard had a single setup
                    455 rwhp/ 458 rwtq
