just dynoed and got 210whp/238wtrq at the wheels.
My 2" crushed-bent exhaust and Midas catylitc
converter is killing the top end as the engine is
maxing out the 36 lbs. injectors. 85% duty cycle on
the injectors according to the math should be right at
300hp flywheel. The engine is cosuming the fuel but
cannot put the power down due to the corked exhaust.
Timing was at 28 degrees and the air-fuel ratio was
holding 12.5:1.
100cpi metal cat along with a true 2.5" should be
interesting to see what it rewards as power starts to level off around 4K RPMs.
I'll save band width with a link to pics below:
http://www.beretta.net/board/ib3/iko...0;r=1;&#entry4
holding 12.5:1.
