Can I use the MAF/MAP from a car with the SC'd 3800 to work with a 3400 turbo project? I'd like to get my hands on a good set of low mileage injectors too. Are there any problems using either the series 2 or series 3 injectors?
Turbo Questions!
Tags: None
You can use the MAP from SC 3800 but find BIN from one of those and change all the MAP info in the ECU so it works. Use an LS1 MAF. Injectors will need to be a minimum of 36# which is what the SC 3800 use or I have a set of Accels I can sell you1994 Chevy Corsica. Parted out. Just a rotting shell now
Best 1/4mile ET - 12.9
Best 1/4mile MPH - 111
1997 Ford Ranger Splash
Daily Driver
Yeah, stick with a 3" MAF so you don't go from 2.5" charge pipe to some huge MAF and back down again. That causes weird readings from the turbulence. LS1 MAFs are available in 3" and read more flow. But not all LS1's were 3" some were 3.5" like the SS I think and corvette ones.
I think it's possible too if you had the hardware to re-program (calibrate) the MAF for higher flow. I know people do the opposite, so that they can use a larger MAF for less restriction but re-calibrate it so it matches what the stock MAF was on the flow readings.sigpic
The stock MAF maxes out quite easy. Need to use a bigger one or one capable of reading more. Re-programming it to work with a stock one will be a waste of time1994 Chevy Corsica. Parted out. Just a rotting shell now
Daily Driver
shouldn't this isn't in the turbo section?Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
I'm running the 3400 one which is 55psi max I think. As far as I know that plenty for what these motors can make on stock parts. Just make sure you upgrade to a 255lph pumpOriginally posted by Daguse5853Z View PostWhat about the fuel pressure regulator?1994 Chevy Corsica. Parted out. Just a rotting shell now
Daily Driver
yeah i called about the fuel pump a few months ago but I havent gotten around to ordering it yet95 Z26 3400/OBDII/GETRAG
Just get the universal GM one from Walbro, it drops right in, and they are under 100 bux on e-bay for a kit.
I have the high pressure 255 one in ole red, and I really need to put it into the pink car since thats the one with all the motor in it.
Stay away from the ebay walbro's!!!!!
They are junk and are prone the failure. Be sure to search around before submitting your purchase, it is not fun having to drop the tank twice/three/four times! Worst of all, they probably will not warranty the pump either. $$$$Lifting my front wheels, one jack at a time.
This appears to be a good site for pumps and high flow injectors particularly the shorty injectors used on the later engines. Another way to insure excellent fuel flow is to add an inline external fuel pump. A pump wiring system better than stock is essential. Before I installed my Walbro pump which I hope is an original, I could hear my fuel pump speed change with the turn signal flashing, thicker wires are a plus.
Welcome to Racetronix: Your Premier Automotive Destination for Fuel Pump Performance, Precision Fittings, Top-notch Hoses, Adapters, Catch Cans, Tank Expertise, and many more. Rev up your automotive journey with us!
Here is a bypass fuel pressure regulator which I plan to swap to for a better regulator to deal with returnless fuel rails found on the newer engines for those who may be planning to do a complete swap;
Aeromotive 13101 EFI Bypass Fuel Pressure Regulator
eBay Motors makes it easy to find parts for cars, trucks, SUVs, motorcycles & more. We even offer a massive selection of new & pre-owned classics, hot rods, exotics, vans, ATVs, RVs, boats and more at eBay Motors. Shop for your next vehicle, or start selling in a marketplace with 171 million buyers.
Speaking of counterfeit parts from China, I just received an email from the Chinese company apparently responsible for all of the budget priced expensive performance items we see on Ebay. It's when they place the O.E. name on their product that they are playing down right dirty;
be careful they make 2 versions of the walboros u want a high presure version made for turbop/supercharger cars. the non highflow version drops off flow pretty fast as fp increases#1 1989 RS - THE L98 AND LT1/LS1 KILLER
1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
#2 95 granprix 3100 all stock for now
ported heads and cam comming soon, megasquirt ems and turbo down the road
