Nitrous on High mileage engine
  • greengrandam84
    • Oct 2008
    • 30
    Just wondering why I always hear its not the best thing to run N20 on an engine with high miles?(100k+) What would need to be done to make it safe or safer to run Nitrous?
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    There are many things wrong with using a motor not setup and/or with high miles.
    The ring gap is wrong
    Tune is off (fuel timing/spark)
    Cam is not right for it
    Everything is jsut not spec'd for it
    With that aside, it's a cheap durable engine.... Spray it to death!
    • greengrandam84
      • Oct 2008
      • 30
      Kinda confused?
      Only looking to run 35-50 shot. What if one were to get an MSD ignition to control the spark/retard and run it a bit rich to prevent detonation?
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        Is this just a car to beat on at the track or will it have a life in the DD world?
        • greengrandam84
          • Oct 2008
          • 30
          it is and will still be a D.D.
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            I would just get it dyno tuned for a 50 shot and call it done. Or you can pick up learning the curve of OBD1 and moates stuff (search google "moates")
            • greengrandam84
              • Oct 2008
              • 30
              OBD1? its an 00' Grand Am isnt it OBDII?
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                How were we suppose to know???????????????????????????????????
                Find out if you can get HPtuner or someone with a DHP to let you tune your car.
                  DOOO IT!!!!!!!!!!
                  I ran a 100 wet shot on my stock 3400 daily... Granted it was a rebuit motor... BUT I still went through FelPro headgaskets pretty easily... This new motor in the project will always get GM headgaskets hopefully that holds up to nitrous better
                  • greengrandam84
                    • Oct 2008
                    • 30
                    well I'm about to do the LIM gasket replacement. Should I used the felpro perma-dry gaskets or get the GM ones? or is there no difference for the LIM gasket. Im def. not gonna run 100 shot, hoping for 50 and maybe a 75 here and there.
