New turbo setup..
  • RedZMonte
    • Feb 2004
    • 1378
    New turbo setup..
    So tell me what you think.. I got my thinking changed a little bit
    Now im thinking still build the tubular manifolds but change the X-over to a 2" rather then the 2.25" i have now.. reason being is the Divided flange will reduce anyhow, so i can build it with the 2" and be perfectly fine... The exhaust pulses are gunna be staggered anyhow so it shouldnt be an issue, what do you think?
    T4 Divided turbo flange:
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
    a dual crossover pipe? i don't think i've heard that one in a while
    • RedZMonte
      • Feb 2004
      • 1378
      No, my bad that wasnt wrote very well, i fixed it.
      Stock X-over is 2.25" on the DOHC and the Divided flange will from what i can see only allow me to feed at 2" pipe into it.. i would think that a 2" x-over should be sufficent..?
      S
      Shane "RedZMonte"
      • timg
        • Feb 2004
        • 718
        Sounds good to me. The other option is to start each bank at 2.25" then drop to 2" immediately after the wastegate and before the flange. This should improve boost control.
        Tim
        325 whp 350 lb-ft
