Best place to buy t3/t4 turbo??
  • Maetrix66
    • Dec 2003
    • 61
    What is the cheapest place to buy a decent t3/t4 turbo??
    Looking for one with a .63 exhaust wheel.
    It\'s Alive!
    It\'s Alive!
  • Anonymous
    There is this new place, it's like an online bidding place. www.ebay.com
    • Maetrix66
      • Dec 2003
      • 61
      Wow, that place is fricking awesome! I've never heard of it before!
      LOL. Ok, fair enough, let me fix my statement.
      Does anyone want to buy a factory rebuilt Garrett T-3 turbo with a .42 wheel??
      It\'s Alive!
      It\'s Alive!
      • Anonymous
        Garrett is a company that you can byu turbos from. Try talkign to them....
        LOL sorry, just had to. You probably can find one off of Ebay, they have 18 pages under the search "turbochargers." I'm sure 1 out of the thousands of results has those specs. Then you will probably have to have it rebuilt, but that will be udner 500.
        • phantom505
          • Jan 2004
          • 70
          Acutally I wouldn't buy one of eGay. I would go find a shop that can offer you one with a clipped wheel. Then you can go .81 A/R and not hurt your spooling. Do some shopping.
          It\'s ugly, and turbocharged!
          264 HP and 284 ft/lbs at the wheels(@9psi), power curve like none other!
          And the transaxle to get it to the ground!
          • brian89gp
            • 554
            Since you have a choice of any compressor and turbine, I would avoid a clipped wheel.
            • el_roy1985
              • Apr 2004
              • 40
              what is a clipped wheel? I need to start learning about this crap if I plan on turboing my car next winter
              1996 Beretta, 3400/5 speed, internet Tune, FFP UDP, Billet/poly mounts, ported intake manifolds, WAI, 2.5" mandrel exhaust, Borla ProXS, Intrax, KYB, poly front end kid, welded a-arms, strut, shock and sub-frame braces.
              • nocutt
                • 123
                When an angle is cut into the turbine's outer wheel...it theoretically increases CFM indirectly, because now one can move the time the turbo makes usable boost at a later RPM, however it reduces the efficiency of the turbo...trade off!?!?
                Maetrix66,
                I think you meant .63 housing try www.turbobuick.com and www.turbobuicks.com ...the for sale section will usually have some decent prices!
                3800 S3 intercooled turbo...
                • phantom505
                  • Jan 2004
                  • 70
                  I can almost garuntee I'm the only one on these boards that has a turbo of that style. I also make "ideal" power (meaning if you calculate my displacement, boost level inc. IC, and engine RPM, it is the maximum calculated). It starts to boost in the high 2000's and is at full boost up to about 9 psi by about 3500 RPM. There is no drop off in power until it shifts. To me you can't ask for much better.
                  Besides, I have the numbers to show it. Do you have a turbo that's putting out better power? (accounting for displacement of course)
                  • RedZMonte
                    • Feb 2004
                    • 1378
                    I would run a larger A/R then that. I would do closer to a .80 with a "P". i would actually step up to a straight T04E, But that is just me....
                    T3/T04E .80 A/R P trim would be a fun combo for the 3100. I would not run more then 10psi intercooled.
                    hell, my roomate runs that turbo w/ a .70 a/r on his 1.8L integra and it spools fast! Quite a few people run 60-1 Standards (T4 Based Turbo) on their 1.6-2.4L 4cyl imports here in colorado without a problem...
                    RedZ
                    Shane "RedZMonte"
                    1992 Lumina Z34-VIRGIN (RIP)
                    1992 L67 Lumina Z34 (SOLD)
                    1990 Turbo Grand Prix (SOLD)
