Looking for boost... ;-)
  • Monzsta
    • Jul 2007
    • 132
    Okay, I have two turbos. One is a TDE04L-10T I snagged off a junked Cummins 3.3l diesel. Not much info on this little bugger at all. The other is another diesel turbo, this one from a GM 6.5l engine. (IHIRHC6 GM-8 ). The little one looks like I could almost throw it in there hard enough and it would work. There's still room for the battery, wouldn't need to intercool it for a few pounds of shits and giggles. My question is what is too small? I'm only looking to make a couple pounds and break the ice, so to speak, paving the way for the bigger turbo in the future. If I put the bigger turbo in there now it means more downtime and work, and money. (intercooler, wastegate, BOV).
    Just want your thoughts on this before I get stupid.
    '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
    1/8 mile 9.72@75 mph, 2.0 60 foot
    Just save your time and do it right with IC the first time
      X2 from me... even low boost benefits from a proper IC
      • Monzsta
        • Jul 2007
        • 132
        Well, the tiny turbo's got way too much bearing play for my liking. So it's time to start intercooler hunting.
        • RedZMonte
          • Feb 2004
          • 1378
          TDO4's are tiny. thats what the single cam honda's run on some of the smaller kits... WAY too small. it would choke you as much or more then it helps you... A good T3/T4 is your best bet and they are relativly cheap.
          S
          Shane "RedZMonte"
          1992 Lumina Z34-VIRGIN (RIP)
          1992 L67 Lumina Z34 (SOLD)
          1990 Turbo Grand Prix (SOLD)
            i'm assuming this is for the 3400 lumina in the sig?
            if so, best options for a DD car are either T3/T4 hybrid(as suggested above), or a T61. either one can make a damn good turbo on that motor depending on exactly how much boost you're looking for.
            • timg
              • Feb 2004
              • 718
              The bigger turbo should work. Remember, that diesel may be twice the size, but it only revs half as high.
              Tim
              325 whp 350 lb-ft
              • no_doz
                • Sep 2005
                • 912
                heres a compressor map for the larger turbo-stay away from the TD04 & keep it for a 4 cylinder, quad, or motorcycle project
                • MidnightriderZ24
                  • Jan 2005
                  • 699
                  the diesel 6.5 turbo is a damn good turbo. theyre close in comparison to a t3/t4. make sure u get the lastest design as of its bigger compressor. intercool it and you will have a tire roasting beast!
                  [SIGPIC]
                  12.268@117... 11's to come!
