3400 turbo? tranny problems?
  • recci03
    • Apr 2009
    • 25
    hey guys. ive been debating for sometime now for a little boost. ive x'ed the idea for a supercharger, and im not looking towards the turbo side. their are a few questions though.
    1. my car and tranny have around 62000 miles on it, and i'd love not to break anything seeing that this car is my daily. i wanted to see what boost setting is good, or what im going to have to do (note: im not making this a track car, i just want some rolling power, no launching)
    2. i was looking at like t3/t4 turbo's or a 70 trim, but i just need to know what is the best bang for my buck turbo, nothing too rediculous, just something that doesnt spool at idol.
    3. what is it going to run me in the long run, like piping, wastegate, timer, blah blah blah. just a quote would be awesome.
    thanks a lot in advance for the help everyone.
    - 03 Monte Carlo LS
    - 2.5" Magnaflow exhaust
    - ceramic Pacesetter headers
    - UDP and alternator pulley
    - LS6 valve springs and MMS stage 1 cam
    - d.i.y. intake with K&N con filter
    for a little guy, he runs pretty good
  • MidnightriderZ24
    • Jan 2005
    • 699
    i used a manual trans, but your 4t60e could use a shift kit to handle sloppy shifts and help band/clutch life. best bang for your buck turbo depends on what power you want.
    [SIGPIC]
    12.268@117... 11's to come!
    • Azrael
      Accelerating uphill in OD
      • Apr 2005
      • 763
      It depends on the amount of boost you plan to run. The 4T60's are rated for ~280 lbs-ft of input torque with reasonable reliability.
      1995 Grand Am SE
        depends on weight as well. being an 03, it's gotta be a 4t65e. your MC should weigh in around 3400-3500, depending on options. as long as you don't go too ridiculous with the boost it should survive.
        but it wouldn't hurt to try and shave weight somewhere or install a LSD or run tires that aren't so sticky that when they hook the diff explodes....
        • RedZMonte
          • Feb 2004
          • 1378
          Buying brand name parts expect to spend about $2500-$3000 total. i would keep it at a conservitive 5-7PSI. If you do it correctly (injectors, tune, IC, ect...) you should not have problems with engine or tranny. Obviously if your power braking it and launching hard, doing burn outs and what not your tranny will prob. give out on you sooner or later. Large T3/T4 hybrid or a large straight T3 will be a good low boost turbo for your car and will be fairly compact. My 4T60-E is beat on quite often and it is holding up just fine.. I am at 5000ft elevation and large turbo (lag) so it doesn't build much boost till ~3200 rpms helps my trans from exploding cause it eases into boost nicely.
          Also make sure to run a Good Trans cooler... will help the tranny stay alive in the long run. I have a universal B&M super cooler on mine.
          S
          Shane "RedZMonte"
          1992 Lumina Z34-VIRGIN (RIP)
          1992 L67 Lumina Z34 (SOLD)
          1990 Turbo Grand Prix (SOLD)
          • SilverGAGT2002
            GTslow
            • Sep 2009
            • 84
            Turbo kit
            I may be willing to let go of my turbo kit that came off a 3400 Grand AM GT $1,250 shipped
            Comes with the boost gauge
            Garrett GT32R Turbo
            IC
            IC piping
            Misc oil feed lines
            2002 Pontiac Grand AM GT K&N WAI, Pacesetter 2.5' piping/SLP loudmouth exhaust, Magnaflow High Flo Cat
            2006 Pontiac GTO 6.0/Iron 370, Kooks 1 7/8 Longtube headers, Mahle forged pistons, Scat H-beam forged rods, Custom Cammotion boost cam, Magnaflow Catback exhaust.
            Coming soon: Trickflow 235 heads & Magnacharger TVS 2300
