Boost and Check Valve questions...
  • RedZMonte
    • Feb 2004
    • 1378
    So i was just curious, you guys running boost on your NA motors, do you run a check valve before the FPR to keep boost from going into it? Same question for the Accum. Valve on the Auto trans?
    i havnt ran one on mine ever and thinking it might be a good idea, not sure if thoes parts where designed for boost so i don't know the effect on them in the long run.... ive ran them like this for years without any real problems but what is your inputs?
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
  • mfewtrail
    ~600hp worth of 3.1's
    • 170
    Shane, just for what it's worth: The Turbo Grand Prix's do not use a check valve at the FPR(same part # FPR as the NA 3.1's), but they do have a check valve before the vacuum modulator on the transaxle.
    The standard check valves GM uses for the vacuum lines going to the HVAC, etc. = what these cars have from the factory. Most of us use "HELP!" part #47150 as replacements.
    Matt F.
    TGP 1/4 mile times
    http://photobucket.com/albums/y33/mfewtrail/
    1990 TGP Coupe VIN Database
    • RedZMonte
      • Feb 2004
      • 1378
      Cool dude! i thought i remembered a check valve there on my TGP but its been years sence i have had it so i couldnt remember. I could just let it bleed off i would assume, it wouldnt need to be resurculated.... I would assume.... what if i just put a check valve in line so once it got into boost it just blocks all vac and boost from the modual?
      S
      Shane "RedZMonte"
