Turbo suggestions for otherwise stock engines
    ok, being a sunday, with nothing to do, i got bored.... very bored. so i started making a list.... what i came up with was basically throwing in stock specs for various 60V6 motors into the squirrelperformance turbo calc and then going through EVERY turbo to see which ones came even close to being suitable at different boost levels...
    now, my definition of "suitable" was this:
    efficiency had to stay above ~60% at all times where the boost threshold was met. i was actually amazed at how many passed this, but that's why there are other req's as well...
    i wanted a NICE margin between the calculated airflow and the surge threshold at any time there was boost. this knocked out quite a few.
    then, at higher boost levels, i removed all of the turbos that at any time went beyond the highest speed shown on the charts to get rid of the turbos too small to make enough boost without spinning at ridiculous RPMs.
    and this is what i have so far... at the moment, it's just the MPFI 2.8 gen 1 motors as installed in a F-body(fiero and FWD apps are probably close enough to use the same charts actually.... and the iron-headed 3.1MPFI as well, methinks), but i'm planning on working up through the generations as i have time.
    now, for the disclaimer:
    THIS IS MEANT AS SUGGESTIONS ONLY!
    meaning, each individual vehicle and application will likely need something a bit different, but this should give you a good idea of where to start. this is also assuming you have a more or less stock motor(SMALL cams or LIGHT porting won't change things too much), after that, all of this gets thrown out the window.
    2.8 RWD Iron Head MPFI:
    ~5PSI ~175HP
    GT2252
    GT2560R
    GT2854R
    GT2860R-2
    GT2860RS
    GT2871R-1
    GT2871R-2
    GT2871R-3
    GT2876R
    GT3071R
    GT3076R
    GT3267-1
    GT3267-2
    GT3271
    GT3571
    GT3776
    GT3782R
    T04E-40
    T04E-46
    T04E-50
    T04E-54
    T04E-57
    T04E-57 DBB
    T04E-60
    T04E-60 DBB
    T04B S-3
    T04B V-1
    T3 60
    T3 Super 60
    TB0348 86-87 GN TURBO
    TS04
    TD04H-15G
    TD04H-16T
    TD04H-18T
    TD04H-19T
    TD05-14B
    TD05-14G
    TD05HR-16G L
    TD05H-16G S
    TD05H-18G
    TD06-16G
    TD06-17C SY/TY TURBO
    TD06H-20G
    BRL4219E
    K04-2275
    K16-2467
    K26-1
    K26-2
    K27
    K14-2464
    K24-2470R
    K26-2664G
    RS2-2672
    53150-143
    66130-178
    66130-200
    66130-224
    ~10PSI ~223HP
    GT2056
    GT2252
    GT2259
    GT2554R
    GT2560R
    GT2854R
    GT2860R-1
    GT2860R-2
    GT2860RS
    GT2871R-1
    GT2871R-2
    GT2871R-3
    GT2876R
    GT3071R
    GT3076R
    GT3267-1
    GT3267-2
    GT3271
    GT3571
    GT3776
    TO4E-40
    TO4E-46
    TO4E-50
    TO4E-SUPER 50
    TO4E-54
    TO4E-57
    TO4E-57 DBB
    TO4E-60
    TO4E-60 DBB
    T04B S-3
    T04B V-1
    T3 50
    T3 60
    T3 SUPER 60
    TB0348
    TD04H-13T
    TD04H-15G
    TD04H-16T
    TD04H-18T
    TD04H-19T
    TD05-14B
    TD05-14G
    TD05HR-16G L
    TD05H-16G S
    TD05H-18G
    TD06-16G
    TD06-17C
    TD06H-20G
    TE04H-13C11
    HX30
    HX35
    BRL4219E
    S200
    S2B
    K04-2075
    K04-2275
    K16-2467
    K26-1
    K26-2
    K27
    K14-2464
    K24-2470R
    K26-2664G
    RS2-2672
    S256
    53130-143
    66130-178
    66130-200
    66130-224
    ~15PSI ~271HP
    GT2056
    GT2252
    GT2259
    GT2554R
    GT2560R
    GT2854R
    GT2860R-1
    GT2860R-2
    GT2860RS
    GT2871R-1
    GT2871R-2
    GT2871R-3
    GT2876R
    GT3071R
    GT3076R
    GT3267-1
    GT3267-2
    GT3271
    GT3571R
    GT3776
    T04E-40
    T04E-46
    T04E-50
    T04E-56
    T04E-50
    T04E-SUPER 50
    T04E-57
    T04B S-1
    T3-60
    T3-SUPER 60
    TB0348
    TD04H-13T
    TD04H-15G
    TD04H-16T
    TD04H-18T
    TD04H-19T
    TD05-14B
    TD05-14G
    TD05HR-16G L
    TD05H-16G S
    TD05H-18G
    TD06-16G
    TD06-17C
    TD06H-20G
    HX35
    S200
    S2B
    K04-2275
    K16-2467
    K26-1
    K26-2
    K27
    K24-2470R
    K26-2664G
    RS2-2672
    S256
    66130-178
    66130-200
    66130-224
    ~20PSI ~318HP
    GT2560R
    GT2860R-2
    GT2860RS
    GT2871R-1
    GT2871R-2
    GT2871R-3
    GT2876R
    GT3071R
    GT3076R
    GT3267-1
    GT3267-2
    GT3271
    GT3571
    GT3776
    T04E-40
    T04E-46
    T04E-50
    T04E-SUPER 50
    T3 60
    T3 SUPER 60
    TB0348
    TD04H-18T
    TD04H-19T
    TD05HR-16G L
    TD05H-16G
    TD05H-18G
    TD06-16G
    TD06-17C
    HX35
    S200
    S2B
    K26-1
    K26-2
    K27
    K24-2470R
    RS2-2672
    S256
    66130-178
    66130-200
    66130-224
    now, should anyone wish to challenge what i've come up with, feel free to do so.
    that is what i based all of these off of for the ironheaded-2.8s. adjust the desired power level as necessary to change the peak boost.
      3.4 iron head
      3.4 RWD Iron Head SFI:
      ~5PSI ~206HP
      GT2860R-2
      GT2860RS
      GT2871R-1
      GT2871R-2
      GT2871R-3
      GT2876R
      GT3071R
      GT3076R
      GT3267-1
      GT3267-2
      GT3271
      GT3571
      GT3582R
      GT3776
      GT3782R
      GT3788R
      GT3794VA
      GT4082
      GT4088-1
      GT4088-2
      GT4094R
      GT4094VA
      GT4294
      GT4594 (PORTED SHROUD)
      T04E-46
      T04E-50
      T04E-54
      T04E-57
      T04E-57 DBB
      T04E-60
      T04E-60 DBB
      T04B 60-1
      T04B 62-1
      T04B H-3
      T04B S-3
      T04B V-1
      T04B V-2
      T61
      T64
      T66
      T04Z
      TB0348
      TS04
      TD04H-19T
      TD05HR-16G L
      TD05H-16G S
      TD05H-18G
      TD06-16G
      TD06-17C
      TD06H-20G
      HX30E-7765AX
      HX40-B8554M
      HX35
      H1E-8284AD
      S200
      S2B
      K26-1
      K26-2
      K27
      K26-2664G
      RS2-2672
      S256
      S258
      66130-178
      66130-200
      66130-224
      ~10PSI ~262HP
      GT2056
      GT2252
      GT2560R
      GT2860R-2
      GT2860RS
      GT2871R-1
      GT2871R-2
      GT2871R-3
      GT2876R
      GT3071R
      GT3076R
      GT3267-1
      GT3267-2
      GT3271
      GT3571
      GT3582R
      GT3776
      GT3782R
      GT3788R
      GT3794VA
      GT4082
      GT4088-1
      GT4088-2
      T04E-40
      T04E-46
      T04E-50
      T04E-SUPER 50
      T04E-54
      T04E-57
      T04E-57 DBB
      T04E-60
      T04E-60 DBB
      T04B 60-1
      T04B 62-1
      T04B H-3
      T04B S-3
      T04B V-1
      T04B V-2
      T61
      T66
      T3 60
      T3 SUPER 60
      T04Z
      TB0348
      TS04
      TD04H-18T
      TD04H-19T
      TD05-14G
      TD05HR-16G L
      TD05H-16G S
      TD05H-18G
      TD06-16G
      TD06-17C
      TD06H-20G
      HX30E-7765AX
      HX40-B8554M
      HX35
      H1E-8284AD
      S200
      S2B
      S300
      K26-1
      K26-2
      K27
      RS2-2672
      S256
      S258
      66130-178
      66130-200
      66130-224
      ~15PSI ~319HP
      GT2560R
      GT2860R-2
      GT2860RS
      GT2871R-1
      GT2871R-2
      GT2871R-3
      GT2876R
      GT3071R
      GT3076R
      GT3267-1
      GT3267-2
      GT3271
      GT3571
      GT3582R
      GT3776
      GT3782R
      GT3788R
      GT3794VA
      GT4082
      GT4088-1
      GT4088-2
      GT4294
      T04E-40
      T04E-46
      T04E-50
      T04E-SUPER 50
      T04E-54
      T04E-57
      T04E-57 DBB
      T04E-60
      T04E-60 DBB
      T04B 60-1
      T04B 62-1
      T04B S-3
      T04B V-1
      T04B V-2
      T61
      T3 SUPER 60
      T04Z
      TB0348
      TD04H-18T
      TD04H-19T
      TD05HR-16G L
      TD05H-16G S
      TD05H-18G
      TD06-16G
      TD06-17C
      TD06H-20G
      HX30E-7765AX
      HX40-B8554M
      HX35
      S200
      S2B
      S300
      K26-1
      K26-2
      K27
      K24-2470R
      RS2-2672
      S256
      S258
      66130-178
      66130-200
      66130-224
      ~20PSI ~375HP
      GT2860R-2
      GT2871R-1
      GT2871R-2
      GT2871R-3
      GT2876R
      GT3071R
      GT3076R
      GT3267-1
      GT3267-2
      GT3271
      GT3571
      GT3776
      GT3782R
      GT3788R
      GT3794VA
      GT4082
      GT4088-2
      T04E-40
      T04E-46
      T04E-50
      T04E-SUPER 50
      T04E-54
      T04E-57
      T04E-60
      T04B 62-1
      T61
      TD04H-19T
      TD05HR-16G L
      TD05H-18G
      TD06-17C
      TD06H-20G
      HX30E-7765AX
      HX40-B8554M
      HX35
      S200
      S2B
      S300
      K27
      RS2-2672
      S256
      S258
      66130-224
      • Jonpro03
        • 362
        Ya, you are pretty bored.
          considering it takes me a solid 2 hours of nonstop key-punching, yeah.... pretty bored.
          working on the LB6/LH0 now, then the LQ1, L82, LA1, LG8 and ending with the LX5. the newer VVT stuff is WAY too variable to make general statements with easily.
          • Hard Driver
            • Aug 2010
            • 77
            You got to be kidding,is this suppose to be of some use? I can narrow it down to one of two compressors using maps done by hand.
              i can also pick out the perfect compressor with a setup i'm familiar with, but it's interesting to see what works well with each motor at different pressure ratios.
                OK, gen 2 2.8 and 3.1, i think it's enough for tonight(and the page).
                aluminum head 2.8
                ~5PSI ~168HP
                GT2056
                GT2252
                GT2554R
                GT2560R
                GT2854R
                GT2860R-2
                GT2860RS
                GT2871R-1
                GT2871R-2
                GT2871R-3
                GT2876R
                GT3071R
                GT3076R
                GT3267-1
                GT3267-2
                GT3271
                GT3571
                GT3582R
                GT3776
                GT3782R
                GT3788R
                GT3794VA
                GT4082
                GT4088-1
                T04E-40
                T04E-46
                T04E-50
                T04E-54
                T04E-57
                T04E-57 DBB
                T04E-60
                T04E-60 DBB
                TO4B 60-1
                TO4B 62-1
                TO4B H-3
                TO4B S-3
                TO4B V-1
                TO4B V-2
                T61
                T3 60
                T3 SUPER 60
                T04Z
                TB0348
                TS04
                TD04H-15G
                TD04H-16T
                TD04H-18T
                TD04H-19T
                TD05-14B
                TD05-14G
                TD05HR-16G L
                TD05H-16G S
                TD05H-18G
                TD06-16G
                TD06-17C
                TD06H-20G
                HX30E-7765AX
                HX35
                H1E-8284AD
                BRL4219E
                K16-2467
                K26-1
                K26-2
                K27
                K14-2464
                K24-2470R
                K26-2664G
                RS2-2672
                66130-178
                66130-200
                66130-224
                ~10PSI ~214HP
                GT2056
                GT2252
                GT2259
                GT2554R
                GT2560R
                GT2854R
                GT2860R-1
                GT2860R-2
                GT2860RS
                GT2871R-1
                GT2871R-2
                GT2871R-3
                GT2876R
                GT3071R
                GT3076R
                GT3267-1
                GT3267-2
                GT3271
                GT3571
                GT3582R
                GT3776
                GT3782R
                GT4082
                T04E-40
                T04E-46
                T04E-50
                T04E-SUPER 50
                T04E-54
                T04E-57
                T04E-57 DBB
                T04E-60
                T04E-60 DBB
                T04B 62-1
                T04B S-3
                T61
                T3 50
                T3 60
                T3 SUPER 60
                TB0348
                TD04H-13T
                TD04H-15G
                TD04H-16T
                TD04H-18T
                TD04H-19T
                TD05-14B
                TD05-14G
                TD05HR-16G L
                TD05H-16G S
                TD05H-18G
                TD06-16G
                TD06-17C
                TD06H-20G
                HX35
                BRL4219E
                S200
                S2B
                K03-2075
                K04-2075
                K04-2275
                K16-2467
                K26-1
                K26-2
                K27
                K14-2464
                K24-2470R
                K26-2664G
                RS2-2672
                S256
                S258
                66130-178
                66130-200
                66130-224
                ~15PSI ~260HP
                GT2056
                GT2252
                GT2554R
                GT2560R
                GT2854R
                GT2860R-1
                GT2860R-2
                GT2860RS
                GT2871R-1
                GT2871R-2
                GT2871R-3
                GT2876R
                GT3071R
                GT3076R
                GT3267-1
                GT3267-2
                GT3271
                GT3571
                GT3776
                GT3782R
                GT4082
                T04E-40
                T04E-46
                T04E-50
                T04E-SUPER 50
                T04E-57
                T04B 60-1
                T04B S-3
                T61
                T3 60
                T3 SUPER 60
                TB0348
                TD04H-13T
                TD04H-15G
                TD04H-16T
                TD04H-18T
                TD04H-19T
                TD05-14B
                TD05-14G
                TD05HR-16G L
                TD05H-16G S
                TD05H-18G
                TD06-16G
                TD06-17C
                TD06H-20G
                HX35
                S200
                S2B
                K04-2275
                K16-2467
                K26-1
                K26-2
                K27
                K24-2470R
                RS2-2672
                S256
                S258
                66130-178
                66130-200
                66130-224
                ~20PSI ~306HP
                GT2560R
                GT2860R-1
                GT2860R-2
                GT2860RS
                GT2871R-1
                GT2871R-2
                GT2871R-3
                GT2876R
                GT3071R
                GT3076R
                GT3267-1
                GT3267-2
                GT3271
                GT3571
                GT3776
                GT3782R
                T04E-40
                T04E-46
                T04E-50
                T04E-SUPER 50
                T04B S-3
                T61
                T3 60
                T3 SUPER 60
                TB0348
                TD04H-18T
                TD04H-19T
                TD05-14B
                TD05-14G
                TD05HR-16G L
                TD05H-16G S
                TD05H-18G
                TD06-16G
                TD06-17C
                HX35
                S200
                S2B
                K26-1
                K26-2
                K27
                RS2-2672
                S256
                S258
                66130-178
                66130-200
                66130-224
                • 95SleeperAcheiva
                  ArtofOlivia"PocketRocket"
                  • Jun 2006
                  • 694
                  How about just the HX35 and the HX40 on a '04 3.4 push-rod and the 3.4 dohc?
                  • Joseph Upson
                    I like the Holset VGT series turbos for the variability but from my observations some like the HX40 are two heavy for practical use on small motors intended to be quick daily drivers. One member on the Fiero forum has one hanging off the back of his 3800 powered Fiero and he said it weighs about 40 lbs vs my T67 that weighs about 15. I believe he's also had some cracks in his exhaust manifold that maybe associated with the weight.
                    As for using compressor maps for turbo selection, I had been aiming for close to the center of the max efficiency island which is ideal as far as reducing heat generated but not for stop and go driving. The closer you get to the center island on the compressor map generally speaking, the slower the turbo spools up because it's usually a big wheel relative to the motor and attempting to compensate with turbine size may cause you to choke off top end.
                    At 7 psi moving from a twin T3 .60/.48 setup to a single T67 .81 turbine turbo on the 3900 my inlet air temps dropped about 30 deg, which is good for about a 3% performance improvement (1% per 10 deg drop in air temps).
                    The trend I believe is being moved towards now is ignoring compressor maps and going with a turbo that is capable of the hp level you want and proper intercooling. For example, if your goal is 300 hp you don't want to install a 500 hp turbo. I agree with at least a 60% efficiency but I set aside the drive towards 70%+ because if the inlet temps are where they need to be with intercooling you're good to go, unless you're building a racer, otherwise you want the turbo to spool up as quick as possible, so I've lost my focus for a T70 that will do the same job but take a little more time in the process.
                    I like the way the science looks on paper though.
                    • Big_Jeff
                      • Feb 2011
                      • 22
                      could anyone please tell me how to read the compressor maps... i would like to understand more of what i'm looking at for the 3.4 rwd turbo's
                      thanks, Jeff
                      • mickaz
                        • Aug 2004
                        • 350
                        its not a turbo but how well would a V5F vortech S/C would be on a 3500? At 9 psi and at 15... I dont know how to read compressor map and it would help me alot.
                        Mike 60degree addict.
                          Live life 3.7mi at a time
                          • 4555
                          I don't feel this is true. We have been playing with a lot of Holset stuff, and I mean a lot. We have used the hx35 on engines as small as 2.4l dohc 4cyl and boost is coming full on mid-RPM's in 1st, hits like a ton of bricks, running 8psi. Same turbo on 2 2.5l i6 sohc makes 360whp @15psi. 3.5l i6 sohc Hx55 575whp/600wtq 25psi, boost comes in early still (much like the hx35 on 2.5l) on a home made sch10 weld el manifold, 2yrs no cracks or fatigue. This is just a few examples, but have really enjoyed these diesel turbos as of late. Cheap, plentiful, reliable and are generally running 1/2 the boost pressure they are intended since the slower/cooler diesel exhaust gasses need the volume, making the turbines "large" for a petrol engine - yet still have the flow of higher dollar turbos. While some of them are heavy, the non-VGT's aren't much heavier (if any) than their petrol counterparts.
                          Never really mapped the engines they went on, made a manifold, bolted them on, tuned them and watched the clients scream with excitement as they leave the shop.
                            • 4555
                            • Joseph Upson
                              I have no complaints with the power potential of this series at all, but a 40 lb turbo of any brand is entirely too heavy for a job that something 15 lbs or less is available to do. I don't know what the average weight for them is but was told the one used on the Fiero running mid to high 11s quarters weighs 40 lbs.
