t3/t4 Garrett advice
  • tkoforpresident
    Max
    • Feb 2009
    • 710
    What kind of power could be produced running 7-9 psi or so?
    Would I have to use water/meth injection at that psi? How could I avoid not using water/meth injection?
    Is there a general rule of thumb on how big injectors should be based off of desired psi?
    Simple questions for now, thanks
    93 Firebird 3.4
    Old material, but the theories still work. Buy and read (or download).
    • tkoforpresident
      Max
      • Feb 2009
      • 710
      You reccomend this particular book?
      If so... I just might buy it.
      93 Firebird 3.4
        • 9191
        Yes, if you are going to even think about doing a turbo, you need to read that book.
        • timg
          • Feb 2004
          • 718
          42.5 lb/hr injectors should be enough. For a pushrod 3.4, 36 lb/hr injectors from a GTP might even work.
          Water/meth injection isn't necessary for 7-9 psi.
          Generally:
          New Power = Stock Power * (1 + Your Boost Level / 14.7 psi)
          Tim
          325 whp 350 lb-ft
          • tkoforpresident
            Max
            • Feb 2009
            • 710
            thanks guys, I guess my first question should have been "which book should I read before asking questions on turbos" but since we arrived there smoothly I will go ahead and read that book and then report back with a full report and a plethora of questions
            thanks,
            max
            93 Firebird 3.4
            • tkoforpresident
              Max
              • Feb 2009
              • 710
              Here is a more appropriate question...
              How succesful has tuning turbo's been with obd-1? Especially without a wideband.
              Surely it's not optimal but it's probably been done alot with obd-1 setups.
              I know that there are some masks that are more appropriate than $A1 for a turbo'd motor.
              93 Firebird 3.4
              • tkoforpresident
                Max
                • Feb 2009
                • 710
                I don't think these will work. They are multec 2 design unless I am mistaken and I need Multec 1 to replace the injectors currently on my fuel rail. Preferably something that is rated @ 43.5 psi.
                93 Firebird 3.4
                  Well, I know Syclones/Typhoons, GN's/GNX's, ect were OBD1 and didn't come stock with a wideband.
                  • tkoforpresident
                    Max
                    • Feb 2009
                    • 710
                    lol true, true.
                    btw guys, look what I just picked up at Barnes & Noble (their only copy to boot)
                    93 Firebird 3.4
                      W00T! Now shut off your computer and get reading! lol. (j/k) What did it run you?
                      • tkoforpresident
                        Max
                        • Feb 2009
                        • 710
                        35$ for Maximum Boost
                        But I also picked up an old favourite, The Count of Monte Cristo
                        93 Firebird 3.4
                          Ouch, looks like they are still turning a profit on that book. From what I've been told about it, it's worth every penny, though
                          • tkoforpresident
                            Max
                            • Feb 2009
                            • 710
                            Generally:
                            Tim
                            Ok, so using this formula with the *educated guess* that my motor produces 200 hp (at the crank), which if anyone would like to go attain knowledge of my current setup, will probably agree that is either a very reasonable guess or if anything a little less than what it actually is, I have come out to a nice round # of 322.448979 HP @ 9psi (my intended amount).
                            Using the injector calculator I have determined that 33.5 lb/hr injectors are necessary to satisfy this amount of power (@43.5psi). It looks like I have but one option then when it comes to injectors. The ford mustang 5.0 "green top" 42 lb/hr injectors should fit the bill by giving plenty of room to tune, with the chance also of needing slightly more than 33.5# injectors if my bhp estimations are in fact higher than I suggest. Also, they are relatively easy to find on ebay/message boards.
                            Anyone agree/disagree?
                            93 Firebird 3.4
                            • Joseph Upson
                              Generally you'd buy a stand alone wideband controller to tune, Zeitronix, PLX, AEM, etc.
