EGR valve under boost
  • AleroB888
    • Nov 2009
    • 249
    Can someone explain the modes an EGR valve goes into from idle to WOT? I need to know if running boost with the stock EGR setup will merely set codes, or cause damage to the valve.
    This is on a 3400 V6.
    TIA......
  • MidnightriderZ24
    • Jan 2005
    • 699
    no damage, the egr will close when you go wot
    [SIGPIC]
    12.268@117... 11's to come!
      the EGR is only active at cruse RPM's under light load, it's closed at all other times.
      • AleroB888
        • Nov 2009
        • 249
        Thanks for the replies.
        In the Magnuson Gen 4 supercharger kit, it included an adapter that rerouted the EGR tube to the blower inlet. I was trying to find out the reason that was done. If anything, it seems that would make the EGR system less effective than the stock location. And that was originally a low-boost application, 5-6 psi or so.
        • unchained01
          • Jan 2011
          • 388
          I am just going to block that port on the S/C and not use the EGR
          • RedZMonte
            • Feb 2004
            • 1378
            yeah, sucking fresh air in threw the egr basically defeats the point of a EGR, right?. id leave it in stock location or block it off.
            S
            Shane "RedZMonte"
            1992 Lumina Z34-VIRGIN (RIP)
            1992 L67 Lumina Z34 (SOLD)
            1990 Turbo Grand Prix (SOLD)
            • 1996Monte_Carlo
              • Jan 2012
              • 22
              well if its 96 or newer, depending on where you live at, id leave it alone for emissions and inspections, plus if your regular driver i would because it works on on cruising speeds of lower rpm's. it will help with gas
              96 Monte Carlo *Eleanor* 3.1 with colt cam, 8mm msd wires, bosch x4 platinum plugs, CAI with a k&n 3.5 clamp on filter, 2.5" exhaust, 2.5" glass-pack single 2.5" tip, ebc brake rotors, green neons, 8k xenons, fog lamps, 2 12" mtx jackhammers 800watts each with slotted box, and 1200watts sony explode competition amp.
