Twin K04's on a 3500???
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    what do you guys think, Twin cobalt SS turbos on a otherwise stock 3500 in a five speed fiero?
  • Joseph Upson
    NO! with turbos from any car, and that's coming from someone who's done it twice.
    http://www.fiero.nl/forum/Forum2/HTML/084972-2.html
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      are you saying no to turbo altogether? or just to factory turbos?
      • Joseph Upson
        Are you kidding, no to twin turbos.
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          it would be a remote mount, not right on the side of the motor like you did. I've got plenty of room where the lower half of the trunk went, and I'd like to keep them out of sight if possible, not sure I could do it with a larger single.
          • Joseph Upson
            My trunk is still in tact and the turbo is out of sight. If you insist on a low mount it would probably be better to mount it on the front side of the motor so that you have plenty of room for exhaust plumbing. You can use one of the Holley series pumps as an oil scavenge pump, red, blue or black with the internal screen removed. They have all metal pump parts. I use the black version which is the highest or one of the highest flowing. It's in place but not in use at the moment. I did run it initially for a few thousand miles. It's a great alternative to a near $200 dedicated scavenge pump that can't be replaced very easily at a local parts store if it fails.
