"turbo is junk" Any suggestions?
  • Z26-T
    • Apr 2008
    • 486
    So I bought a used garret T3T4 .60/.63 stage 3 turbo. Was told it needed a new center section. Upon dissasembly I found that the turbine wheel contacted the housing. Took the turbine/compressor in to have them balanced. The local turbo company told me the turbine and comressors need to be replaced.. quoted me 800 for a complete rebuild. When we all know you can buy a stage 3 garret for 650. Any suggestions on what to do?
    I have an ebay T3T4 that is a .50 trim (well, at least it was advertised as one). Though the exhaust is a 5 bolt when I need a 4 bolt flange.
    This is to be teamed up with a 3400/3500 with ported top end, 65mm tb, 268/284 seat to seat, 214/230 @ .050, .528/.528 lift, 113 ICL 114 LSA cam.
    Live life 3.7mi at a time
    • 4555
    Have the DP fabricated to accept the new flange/bolt pattern. The 5 bolt is far more common, and the best part is you can substitute the Garrett for the ebay unit
    The ebay turbo is a to4e 46 trim.
    • Z26-T
      • Apr 2008
      • 486
      How well will a 46 trim work on this setup? (This is all loner's stuff if you can't tell :P) His turbo "apparently" is junk. I'm trying to find another local turbo shop to see what they say. When i dissasembled the center section, there was one bushing that was toasted. The turbine was pretty messed up and the compressor has 1 ding on it, which I think the turbo shop did... I didn't see it when I pulled it apart and gave it to them.
      If I'm reading the map correct from http://www.squirrelpf.com/turbocalc/ at around 5600 is when I will be out of efficency with the 46 trim... which isn't bad. Didn't plan on taking it to 6k very often, but a t04 60 trim would be most ideal.. But I could be reading the charts wrong.
        FWIW, the 46 trim(i have an ebay version as well, partially due to John) is an excellent match for an unmodified small port 3100 wanting to run up to stupid amounts of boost. i'm not surprised it runs out a bit soon on a 3400/3500 hybrid.
        • Z26-T
          • Apr 2008
          • 486
          So it would have been perfect when I bought it, when I had a stock Z26. That'll teach me to buy a turbo, then build an engine to accept it. Haha.
          • Z26-T
            • Apr 2008
            • 486
            Decided to mix-n-match. Took the turbine from my ebay turbo, fixed the compressor wheel from the garret and took them both in to be balanced by a different shop. Got them balanced and re-assembled the ebay turbo with the garret intake housing and compressor. So for now i'll be using the ebay 5 bolt exhaust housing.
            • TGP37
              Shadetree Engineer
              • Jul 2011
              • 1027
              What to use an old turbo on?
              • Z26-T
                • Apr 2008
                • 486
                If you want to build the starter drive system, i'm all game :P
                  I've seen people use leaf blowers to start them.
