TGP manifold question
  • TGP37
    Shadetree Engineer
    • Jul 2011
    • 1027
    #31
    a 3-1 instead of a log (my setup will be twin scroll)
    That is the best option imho. Keep them primaries small, 1 5/8" is good up to 1000 whp. No reason to go larger then that. It may feel like it's too small but trust the turbo racers of days past, you will be happy.
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      #32
      16 ga 1.625 was the plan, with cone eng. 3-1 merge collectors.
      • TGP37
        Shadetree Engineer
        • Jul 2011
        • 1027
        #33
        Good collectors are worth every penny, they look like nice collectors. Anything to keep the velocity high...
        If your exhaust port cross section is less then the 1 5/8 pipe cross section, consider using a pipe that matches the port cross section to make the bend then step up to 1.625". Basically extends the exhaust port and reversion wall for greater velocity.
        Did you check the exhaust ports on your heads, do they exit the head perpendicular or are they at a slight angle? My heads are off by 7-8 degrees IIRC, one port is one way and the other two are the other way. Easy to simply weld the primaries perpendicular to the flange/heads but that will create a kink in the path, restriction. So my flange needs to match the angles offset, making it a pita.
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          #34
          I have not checked the port exit angle yet, when I get the engine back out, I'll start the headers hardcore.
          • Guest
            #35
            your ebay turbo is not a twin scroll.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              #36
              it's a divided housing, and it goes way far back into the exhaust housing, I haven't had the housing off, but it appears to go all the way to the wheel. it's going to be setup for twin scroll, and one day, it when the funds permit I'll update to something a little more legit...
              • Guest
                #37
                A divided housing is NOT a twin scroll. I am not trying to burst your bubble here or be mean. Its a simple fact. A divided housing is different.
                Are you going to install those pistons in your current motor, or rebuild a different motor and use the current one as sort of a test/base setup to get the bugs worked out?
                • TGP37
                  Shadetree Engineer
                  • Jul 2011
                  • 1027
                  #38
                  The divided housing will do what he expects, keep the exhaust pulses divided up to the turbine to aid spool. So as long as the headers are piped accordingly. True, it won't be as nice as a twin scroll but it still is better then no divider at all.
                  eric, I've been doing some research into my turbo headers.....I came across some neat stuff which I am sure many can appreciate for turbos. I'm gonna post up a thread later today or tomorrow.
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    #39
                    when the engine comes out for the cam and clutch install, it's going to the machine shop and getting bored for the new pistons. I understand about the divided housing being different, I'm looking into a couple of different options for the turbo anyways, as I'm starting to think the one I have may be a little too small.
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      #40
                      Awesome, I'd love to see the findings!
                      • Guest
                        #41
                        what size is your current turbo? I know you said its a chinese 35r but have you actually measured the wheel to know? If not, then I would
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          #42
                          I do need to measure it still, I'm starting to consider an HX351ve though, or maybe a GT4088r. I might use the "gt35" for the time being, I might not, we'll see.
                          • Guest
                            #43
                            measure first before buying something else. Are you looking to get a chinese 4088r or a real garret 4088R?
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              #44
                              I'm starting to lean more towards the holset to be honest with you, the VGT system is pretty cool, and shouldn't be too tough to make work. if I go the GT4088r route, it'll be a real deal.
                              • caffeine
                                • Jan 2012
                                • 1489
                                #45
                                Borg Warner makes some nice journal bearing turbos too; many say the spool is just as good as the ball-bearing garretts, they are rebuildable, and cheaper.
                                Edit to add: and some are bolt-on replacements for Garrett turbos
                                '86 Fiero, 3500, 4-speed
