Turbo Header Concepts
  • TGP37
    Shadetree Engineer
    • Jul 2011
    • 1027
    Here are some concepts I found while searching information on turbo headers for the 60v6 engine. Mostly deals with pulse tuning the headers for a turbo. A topic I am deeply invested in myself. I need to build my own custom set and well, lets face it.....who doesn't love a pristine set of headers built by your own hands, research, math, etc.
    Pulse Tuning:
    A divided housing will benefit most from 240 crank degree separation of impulses per side. Noting the crank must rotate twice to complete one combustion event for every cylinder. In our 60v6, the next firing cylinder is 120 crank degrees later. Merging every other cylinder will allow the 240 optimal degree of separation. This is convenient for the 60v6 motor as it fires across each bank evenly. Equal length headers will definitely speed up spool if they are plumbed right.
    A set of cut hoses the same length as the primaries, secured in place to simulate the header flange, bend them where they will go and the hose will give a rough path to start with. The primaries can then be designed around the hose paths. If a set of primaries were welded to flow as smooth a transition as the bent hoses, they will flow very well.
    The collector should not have a larger cross section then the cross section of the turbine housing entrance.
    Enhancing the Pulse Energy: (some stuff I found intriguing)
    When the exhaust energy begins to escape the cylinder there is a strong pressure difference across the valve. The gases escape so fast they reach sonic speeds and will not flow any faster until the pressure gradient falls enough to slow the escaping gases.
    When a pressure wave in a pipe enters a larger cross sectional area, a return wave of negative pressure is created and travels back up the pipe. If the pressure wave travels into a smaller cross sectional area a positive return wave is created.
    This is why the stepped diameter from the exhaust port to the exhaust manifold provides greater flow. The escaping gas creates a return pulse of negative value and increase the pressure gradient across the exhaust valve. Which extends the time when the pressure gradient is great enough to support sonic flow of gases creating a stronger exhaust pulse with greater velocity downstream.
    Reading from this article, the writer describes a part to a Formula 1 exhaust header seen in Illustration 1. There is a 10mm step placed to provide a negative return pulse arriving at the back of the exhaust valve while fully open, increasing the pressure difference across the cylinder and the exhaust port.
    Ill. 1
    Placement of the step to return the negative pressure wave just before the escaping exhaust begins to slow. Unless you can monitor exhaust port pressures, time it to land at the exhaust valve at the RPM of peak power. For a street performance engine, use peak torque RPM. For a track engine, use peak HP RPM.
    More steps can be included broaden the range of power. But each included step sacrifices small amount of velocity, returning the energy where it can be useful. A delicate balance towards greater efficiency.
    It MIGHT be beneficial to make a primary the same cross section as the exhaust port. Then create an equally proportioned step at the right spot downstream, timed to benefit cylinder scavenging at the peak power rpm. In a way, tuning the port step to benefit where we want it to. For a turbo, this will allow higher velocity upstream the primary and reduce primary volume for faster spooling.
    The tapered flow in the Illustration above intrigues me. I believe the focusing of the pulse enhances the steps effect. But at the rpm's this header piece was intended for, our motors will need a far more gradual taper, to the point not worth including.
  • TGP37
    Shadetree Engineer
    • Jul 2011
    • 1027
    As I just realized, the speed of sound is through the local medium. When the medium is moving, that changes the speed of the sonic pulses.
    i.e.-soundwaves travelling into a wind of 2 meters per second will travel 2 m/sec slower.
    The exhaust port step, the pulse from the exhaust valve opening reaches the port at speeds roughly 650 meters per second. The returned negative pulse, created from the initial exhaust pulse entering a larger cross sectional area, will not travel back very fast at all. In fact, it will creep back into the exhaust port but end up standing still when it reaches the back of the exhaust valve. Due to exhaust gases escaping a sonic speeds. The returned negative pulse can not over come the speed of the gases escaping.
    The negative pulse just stays there and won't reflect until the flow out of the cylinder goes below sonic speeds. That happens to be exactly when we want the negative pulse to be there. It will augment the flow just as it tips below local sonic speeds. As it will increase the pressure gradient across the exhaust port and cylinder.
    I read the pressure ratio required for sonic flow is 1.9
    Anyone else know a more accurate ratio around the exhaust valve?
