Turbo oil line
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    Turbo oil line
    what are you guys doing for your oil feed to the turbo? is the plugged port above the oil filter suitable for the feed? I was thinking I would unplug it, and just use a length of braided stainless. it looks like 3/8" NPT, is it?
  • Guest
    its 1/8th npt
    5 weeks left
    • caffeine
      • Jan 2012
      • 1489
      Hmm I think it is 1/4" NPT; I'm using a braided line off the plugged port by the oil filter for feed; I installed my oil pressure sending unit in the stock 3500 location.
      I went with -3 braided stainless because that's what was recommended for my turbo. Some say they need either -3 or -4 with a restrictor in it. Best to find out which size is recommended for your turbo.
      '86 Fiero, 3500, 4-speed
      • caffeine
        • Jan 2012
        • 1489
        Make sure you get high pressure braided line with PFTE? lining in it. Not the regular rubber lining.
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          Originally posted by bigcheese View Post
          its 1/8th npt
          brain fart... outside of the threads looked like 3/8" there's a bracket in the way so I couldn't get a good look. I took the bracket off and got a good measure, looks like 1/4" as caffeine said, as the outside of the threads measure approx 1/2". I too am using the stock 3500 oil sender location.
          • TGP37
            Shadetree Engineer
            • Jul 2011
            • 1027
            Could use an oil filter sandwich adapter. No drill/tap needed. Just slip between filter and block and can route oil feed, oil sensors and some have return lines to fit an oil cooler.
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              there's already a drilled and tapped port on the side of the block, if you look at the oil filter, it's at about 10-11 o'clock. I've ordered -4 for the feed, and -12 for the drain.
              • TGP37
                Shadetree Engineer
                • Jul 2011
                • 1027
                Good sizes, -4 and -12. Turbo oil drain, that's something you could put extra work into it and actually pays off. Anything to make the drain graduated just right always helps. If you decide to put a vacuum pump into the crankcase, the vacuum will travel up the drain line into the turbo housing. Probably good for the oil ring seal but it might be worth checking into.
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  that's what I'm hoping for.
                  • Guest
                    3 weeks to go.
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      3 weeks to go.
                      and for his next trick, he'll tell me something I don't know!
                      • stargaazer7467
                        • Nov 2012
                        • 46
                        i used the little square drive 1/4 pipe plug above the oil filter.
                        • TGP37
                          Shadetree Engineer
                          • Jul 2011
                          • 1027
                          How about, half of the sailors you cruise with won't tell as long as you don't ask......lol
