Need some advice on an lz9 nitrous setup
  • SLC87
    • Nov 2014
    • 10
    Hey everyone,
    I am very interested in adding a wet kit to my lz9 and was wondering if anyone had any advice or pictures of this done to help me out.
    This is going in an 06 malibu maxx ss. I would love to gain the same results via a cam and some other intake work but I havent seen much out there in this department.
    I have a full nitrous kit sitting around from an old car. Warmer, Solenoids, Window Switch, WOT switch, etc. I know the mechanical WOT switch is useless on this fly by wire setup so I will have to find another way on that one.
    I also need some advice on a way to have a secondary tune on the car when the nitrous is being used. I have a tune by WAMS and believe that may interfere with using nitrous.
    Thanks
    Tune wise it depends on how much nitrous you plan on using... I was running a 100 shot and my driving tune was good enough to use with the nitrous and not have any issues. It's only a suggestion to remove timing because they assume your currently running the max degrees possible before Knock which would make you knock when running with nitrous... That's not always true.
    I am one of very few who run nitrous on a regular basis... I had a single foger nozzle in the TB spacer between my 3500 intake and 65mm TCE TB... Next year it will be a direct port setup.
    Throttle setup for you, well you could put a micro switch under the dash to get depressed by the pedal when your at WOT, Otherwise you will have to pick up a micro progressive controller this unit is similar to what I have but mine was sold by DynoTune nitrous
    https://www.holley.com/products/nitr...parts/15974NOS
    They have another that doesn't appear to be progressive.
    https://www.holley.com/products/nitr...parts/15982NOS
    Both would work using a 0-5v TPS signal which I'm sure you can get either from the TB going to the ECU, OR from the pedal going to the ECU.
    This was my old setup.
    Tap for fuel
    All of this is changing for next year... I need to tap the fuel line coming from the tank rather than right off the rail and split that to two separate fuel pressure regulators. One for the injectors themselves and another for the nitrous since being 6 nozzles it will have to run at a lower fuel pressure to allow for a larger fuel jet to prevent clogs.
    Possible line routings...
    I still have a lot of planning to do...
    • caffeine
      • Jan 2012
      • 1489
      I ran a 75 shot with no tuning on a push button for drag racing one year. I went through the bottle and then sold the setup again.
      '86 Fiero, 3500, 4-speed
      • Guest
        I would move those distro blocks to be as far away from the headers/exhaust manifolds as possible.
          Yeah, it's still a work in progress... That rendition I was trying to keep the lines all equal length. I'm being told now it doesn't matter as much as one would think.
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            There's a point in which length will and will not matter. Locution to a compression read-out; just be sure the averaged length of line used is not significantly different.
            • stargaazer7467
              • Nov 2012
              • 46
              i need some of those plenum spacers.
                In all honesty they are pretty easy to get made, maybe not cheap tho. Just find a machine shop that can copy the paper gaskets profile and voila you have spacers.
                • SLC87
                  • Nov 2014
                  • 10
                  Thank you for all the advice!
                  Caffeine, I would do a push button setup with just a window, however this is my car for hauling around my daughter and all her stuff so it needs to have all the safeties and shutoffs because every now and again someone else drives it.
                  I would love to do some cam and head work to achieve my goal however I havent been able to find too many examples of what to do in terms of programming and all that.
                  I'd even be willing to just take it to a shop and have it done professionally but I can't find any shops around me (chicago) that have any experience with this platform.
                  Is there an 'upgrade bible' sort of thing for the lz9?
                  • caffeine
                    • Jan 2012
                    • 1489
                    Switch under the pedal with an arming switch is probably gonna be the most cost effective solution
                    • SLC87
                      • Nov 2014
                      • 10
                      Yeah, I think I am gonna go with the one that reads the voltage off the TPS though. I have all the other parts that I need other than application specific adapters so it shouldnt be too expensive. This thing has adjustable pedals and drive by wire so I could see that going bad with a pedal switch.
                      • caffeine
                        • Jan 2012
                        • 1489
                        Being drive by wire though there isn't a TPS. Which is why you probably need a special controller to tap into the drive by wire system
                        • SLC87
                          • Nov 2014
                          • 10
                          Ah ok, good to know that is not what it is called in that type of setup.
                            I'm sure there is a 5v signal coming from the pedal on some wire or the tb so the ecu knows where either one is...
