do tgp's or 3.1T have a 3 bar map sensor or is it a two bar ?
3 bar map sensor
It was a TWICE
If you buy one off of someone...Look for either one of thise numbers: 886, 012, 539, 609..being stamped on the top of the map sensor...where the electrical plug plugs into. Next to thiese numbers are the 4 digit date code. Fist number is the year..then the next 3 are the day of the year.
So one of mine read out 886 6218. 886 indicates its a two bar...then 6 means it was made in 86 and then 218...218th day of the year. (snaged from sunbird turbo)
Another one of mine has 012 8032. 012 2bar...8 year '88 and then 032 day of the year. (snaged from my doner TGP)
If you see 466...that's the wrong number...its on all map sensors.
All 1bar have 039, 883, 460.
There only one 3bar map sensor that I know of...It has 749 embeded on it.88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
