I'm just wondering if anyone has tried to use a powerdyne supercharger and one of our V6. I was looking at a belt driven type, that produces a max boost of 9PSI. the belt type uses no oil, if i read things right, but they do have a gear driven which uses engine oil to lube it. I was just wondering cause with no oil lines it would make instalation much easer.
Powerdyne supercharger
Re: Powerdyne supercharger
Really, a belt driven supercharger? Rare things those are......Originally posted by ProjectMMI was looking at a belt driven type,
LOL anyway, oil lines actually aren't that hard at all to run. But I don't think you read it right, every supercharger, well roots type that is, has some gears on its insides and uses oil. I tend to side with the oens that have a seperate oiling system, that don't use engine oil. Engine oil is hot, plus using actual gear oil is better for the supercharger. We are using GM synchromesh in our Weind SBC blower.
I think the belt drive just meant that it uses the engines serpentine system to actually turn the rotors.
As usual, Aaron showing his ignorance... Norm is using a belt Powerdyne SC in his Beretta. Here is a thread (that was 5 threads below this one) about it:
http://www.60degreev6.com/index.php?...f6b4444f59e848
Not sure if it shows the SC in that thread, but I know in the links to Beretta NET, it has pics. It even shows a pic of what a torn up belt looks like.-Brad-
thanks bszopi for the help, I know a superchargerruner off a belt, thanks not what i ment. there is a belt inside the supercharger so it makes it a really guiet running supercharger. I'll look into those links!
thanks for the help!2002 Pontiac GrandAm GT1
3400 v6
TOG headers
RSM 62MM T-body
FFP underdrive pulley
GRANATELLI MAF
Ported upper intake
MSD DIS 4 ignition box
MSD Wires and coils (pending)
Venom high flow fuel pump (pending)
Actually, Powerdyne makes a "Belt driven" supercharger as in the impeller is "over driven" and turned VIA a belt INSIDE the supercharger, rather then using gears to mesh the two togehter, it allows it to slip some so you don't overboost your charger and just send in superheated air. They also have a gear driven one that is self oiled and never needs maintenence.
--Dave.Dave ... Dave.45 ... DaveFromColorado ... it\'s all me.
Here is a little history in the link below. Go to the last page(p. 7) for pics of the installation.
http://www.beretta.net/board/ib3/iko...=ST;f=9;t=1212
Dave, the Powerdyne BD-11's internal belt is a cog belt and does not slip. The are no internal lubricants need for the BD-11 unit. The new Powerdyne X-11 is a similar setup like Vortec using the engine's oil. Procharger holds it's own oil and needs changing every 3K miles. Vortec uses motor oil to lubricate it's interal gears. It also bleeds off boost to atomize oil for gear lubrication.
Without hot motor oil going through the blower it should yield a lower compressed air tempature.
I know the M62's, M90's, and M112's all have a reservior in them for oil. It just lubricates the gears that connect the snout to the rotors, but that is all the oil is used for. GM says that it should never be changed, although its a good idea to do it every 50k or so. (supposedly those blowers are maintenance free)
Shawn90 Grand Prix STE 3.1 Intercooled Turbo-3100 Hybrid
99 Grand Prix GT
Thanks every one for your help, yopu answered all my question
Ps. Norm, grate looking setup! hope to here what you 1/4 time is! should be impersive!2002 Pontiac GrandAm GT1
3400 v6
TOG headers
RSM 62MM T-body
GRANATELLI MAF
Ported upper intake
