what car to get turbo off of
  • tjbecht
    • Nov 2004
    • 15
    what factory tubo car to get turbo for 3.1 mpfi looking to go about 10psi maybe more
  • Guest
    On what engine, what do you have done to it? what chassis? What tranny? Whats the FDR? Tire size? Etc?
    There's a lot of variables.
    • tjbecht
      • Nov 2004
      • 15
      fwd 3.1 auto corsica and just a general idea of getting a turbo from junkyard to start planning stage
      • oil pan 4
        • 84
        You need to see this.
        What kind of engine do you want to run this with, a 3.1 I know but stock or what?
        Seth
        Camaro 1
        85\' 3.4L, T-5, 3.42gears
        Mods at work on,
        car domain site 03/13 Saab intercooler flow numbers.
        85\' IROC Z28 Ttop 5.0L, auto mostly stock.
        • Froggx
          • Jul 2004
          • 385
          If it's a stock 3.1, I'd say look for a CT-26 off a MK3 Supra. It was a 3.0L engine with a 6500 rpm redline, and those max out at about 14 psi. If your motor is stock, you probably won't be revving that high or running enough boost to max it out.
          • tjbecht
            • Nov 2004
            • 15
            2.8 bored to .40 over with sealed pro pistons a 3.1 crank cam roller rockers and such
            • Froggx
              • Jul 2004
              • 385
              What kind of cam? Did you change the compression ratio beyond the ~9:1 that is stock? You'll have to lower the cr to get more than 10 psi safely in my opinion. Any head work done?
              • Guest
                I hope you used 3.1 pistons, other wise your pistons will get real "friendly" with your heads.
                What cam are you using? Specs, duration, lift, overlap, centerline, LSA, etc.?
                • Froggx
                  • Jul 2004
                  • 385
                  Whoops, I forgot to ask about that feature. I would hope that since that much work went into it that it was obvious that wouldn't work.
                  • tjbecht
                    • Nov 2004
                    • 15
                    yes 3.1 pistons and prob the comp cams 260h along with rockerd and lifters and yes stock compression ratio
