nitrous powered 60 degree v6's
  • Jeff420
    • Dec 2004
    • 20
    I was just wondering how many of you were running the giggle juice. What size shot and what was your e/t times before and after nitrous. I was running a consistant 10.6 in the 1/8th with a cai and a kink bent exhuast(no better than stock) With nitrous i was running a consistant 9.6. My best run was a 9.32. My best 60 footer was a 1.9. all my times were with completely bald 195-65-15 touring ta's(i call them my ghetto junkyard slicks).
    btw, im running a wet nitrous works system 75 shot. tried the 100 shot once but i got the fuel jet backwards and ran way rich.
  • Guest
    internally stock Fiero.
    85 Gt auto tranny. 2.8 liter
    70 shot best time of 14.1 with a 1.8 60'ft and a 8.8 th mile. Dry kit NOS.
    • Anonymous
      Sooner or later, after the motor build, I will be running a 100 wet shot. Hopefully it will also be ina Fiero, an 88GT 5-speed if I can find one...
      • Jeff420
        • Dec 2004
        • 20
        oh yeah, this is in my 96 grand am se sedan btw
        • Quinky
          • May 2004
          • 159
          I am running nitrous on my car.. unfortunatly due to a week motor, and improperly tuned chip I busted a piston..
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            right now i am in the middle of some other stuff and i haven't got times yet but all i can do is a 40 wet shot for the moment. b/c i had a 50 but i set it up to pull fuel from the test port on the rail and it was causing a f/p drop. i have swapped in ford injectors and lowered the fp to 40 to try and scavenge some fp.
            later i will try to either run a dedicated line or maybe splice in be4 the rail. either test port or splicing in i will need a better pump i think. and i am not going over 50 until i get a box.
            • Froggx
              • Jul 2004
              • 385
              Re: nitrous powered 60 degree v6's
              I'm not sure what you drive, but if it's FWD then you did an awesome job launching on those tires.
