Stock Manifold Question
  • Synestral
    • Mar 2005
    • 53
    I'm still a ways from getting my engine out of the car (taking the fenders and hood off cause they're pretty banged up (my brother hit a cow at around 10mph and it layed on them)) so I thought I'd ask here since this could eventually lead to a turbo:
    Are the stock manifolds designed so that I could switch the driver and passenger sides and end up with the outlets pointing towards the driver side and up?
    Barring that, is there a RWD application that I can salvage some manifolds from that has the desired orientation?
    92 Lumina Z34
    Found coolant in the oil and metal in the filter.
    Also found a home in the engine compartment for a turbo and intercooler
    Some pics at CarDomain
  • dbtk2
    • Feb 2004
    • 349
    RE: Stock Manifold Question
    I'm not sure exactly what you are asking. But you can't just take two front manifolds and use those, because the exhaust ports aren't evenly spaced on the rear, so the manifold would be pointed at the passenger side instead of the drivers side. You would probably have to fab something up.
    Shawn
    99 Grand Prix GT
    • TurboGTU
      • 453
      I have never seen a 3.4DOHCs bolt pattern..if it has offset ports like the pushrods..then no.
      • Synestral
        • Mar 2005
        • 53
        Got to the engine today. The manifolds are too short to do what I originally had planned. I do believe the stock manifolds can be used to support a turbo though. Just have to make a custom pipe to connect the two. Or could make some custom shorty headers that go right into a collector then hook them up. But yeah, definitely gonna be custom fab to get a turbo in and looking like it actually belongs there.
        92 Lumina Z34
        • timg
          • Feb 2004
          • 718
          I'm running a stock front manifold on my rear head. It is mounted upside down and facing the drivers side. A custom corssover connects the two to the turbo.
          Tim
          325 whp 350 lb-ft
          • Synestral
            • Mar 2005
            • 53
            That's what I originally thought I could do. Glad to hear it works
            92 Lumina Z34
