i got a set of #36 injectors and 2 of them were missing the plastic retainers for the o-ring on the botton heres a pic of one with and without, the arrow points to the retainer i need, does anyone know where i can get 2 of them?
where to find these retainers for 3800sc injectors?
You really don't need them, as long as you are careful when removing the injectors. They serve no purpose other than retaining the o-ring when the inejctors are not installed.
Marty'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
yeah, once the fuel rail is bolted down, things probably arent going anywhereIf you aren't friends with a liar, you aren't friends with anyone.
Look again, because I am pretty sure there is a lip that the o-ring and injector rest against when they are fully seated into the lower intake (there is on the pushrod engine at least). This will prevent the o-ring from going any further.
I would hope that it is that way....Originally posted by RacerX11Look again, because I am pretty sure there is a lip that the o-ring and injector rest against when they are fully seated into the lower intake (there is on the pushrod engine at least). This will prevent the o-ring from going any further.
Marty
Besides I HIGHLY doubt that youe engine will create enough vacuum, to pull the O-rings into the engine, with the compression that the O-rings experiance when they are installed, it should be a tight squeeze.
I agree about the compression of the o-rings. In the numerous times I have pulled my injectors, I have yet to have a time when all of the o-rings have come out with the injectors. They're squeezed in there so tight that they will slip right over the lip of the injector and stay right inside the manifold.-Brad-
