Twin charged 2.8
  • sabotage
    • Apr 2005
    • 6
    Twin charged 2.8
    has anyone thought of making a twin charged 2.8? using a m90 supercharger and a gt28 or gt32 turbo in a cascading manner???
    I think youd get some impressive results from a system like this... and I know west coast fiero is doing this with 3.8sc engines so with this in mind do you think this would work with a fully built and forged all aluminum 2.8 bored to 3.3?
  • sharkey
    • Jun 2004
    • 2061
    RE: Twin charged 2.8
    a 2.8l, bored to 3.3l??? i figured that out on my desktop dyno, and a 2.8l bored .300" over will make a 3.3l. however, you wont have any cylender walls past .100". as for a 3.1l crank boreing the block .100" over, you can get a 3.3l. i wouldnt trust this for boost, its taking to much out of the cylender walls.
    a better alternative to this would be to start with a 3.4l camaro motor. you could use a 614 street supercharger kit, then run a turbo into that. the motor would have to be stout, or it would kill everything.
    • sabotage
      • Apr 2005
      • 6
      i was thinkin a bowtie block with a 84mm forged crank forged rods and pistons and aluminum headsand maybe the smaller m62 blower actully what kind of power do u think this would make Im hoping 350-400 hp
      • Froggx
        • Jul 2004
        • 385
        IMO it sounds like a complicated way of doing what a turbo alone could do
        • Guest
          I agree......
          Turbo and Nitrous however...........
          MUAHAhahahahahaha
          • Synestral
            • Mar 2005
            • 53
            That's what I was thinking. Now I have to wonder how much nitrous a stock bottom end can handle after balancing and knife-edging with about 10-15 pounds of boost.
            92 Lumina Z34
            Found coolant in the oil and metal in the filter.
            Also found a home in the engine compartment for a turbo and intercooler
            Some pics at CarDomain
            • Cliff8928
              • 532
              Re: RE: Twin charged 2.8
              GM did it.. so it's possible..
              Discover the latest breaking news in the U.S. and around the world — politics, weather, entertainment, lifestyle, finance, sports and much more.
              I doubt that it had a 3.1 crank, that appears to be a '87 and they probably didn't have it then. But then again, GM has the resources for some crazy one-off stuff.
              Cliff Scott
              89 BerettaGT
              04 AleroGX
              Cliff Scott
              89 BerettaGT
              04 AleroGX
              • Froggx
                • Jul 2004
                • 385
                Cliff Scott
                89 BerettaGT
                04 AleroGX
                You're right, not a 3.1 crank, read the caption for the picture of the engine in the link you posted and it says it has a Moldex stroker crank. While unlikely, for all we know it could be the stock bore and all the displacement is brought up by the stroke.
                • Froggx
                  • Jul 2004
                  • 385
                  When you find out, I'd love it if you shared that knowledge with me
                  • Wolf
                    • 181
                    this is one that always enspired me, not exactly what you were asking about, but still friggin cool
                    1995 camaro 3.4 5-speed
                    • Guest
                      If everything goes well, I'll have info on this too. I'm part way through my top end upgrade, turbo upgrade, and will start the Nitrous install shortly.
                      • TurboGTU
                        • 453
                        I would say all turbo. Why in the world would you need high boost (8+psi)down low(pre 2500rpm). That would just create high cylinder pressures at too low of an rpm. Thats if you can get traction out of the hole first. Just like N2O (indused after 3500rpm?/)...you don't need that pressure down low unless you run a diesel engine.
