I was wondering, is there a nitrous kit made that would be a direct bolt on for the 3.4 DOHC? I would like a wet kit made by either NOS or NX. Thanks.
N2O kit for the 3.4 DOHC?
Wet kits are fairly generic... Don't they jsut take a nozzle and spray in fuel and nitrous at the TB or right after it?
Dry kits are the harder ones. There aren't any. You'd have to find some other way to get your ECM to squirt the extra juice, and even then your injectors are almost maxed out stock.1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
1995 BMW 540i, Alpineweiss-III, 6-Speed
1995 BMW 540i, Schwarz-II, Automatic
2004 Honda 919, Light Silver Metallic, 6-Speed
back from the dead wtf?
I bet two things... One, it's for the Iron Head 3.4 pushrod.Originally posted by JimmyP70http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&N=115&y=13&s earchinresults=false&Ntt=NOS%2D05175NOS&x=17
Nitrous Oxide Systems makes this Dry kit for GM 3.4/ 3.8 V6's.
Fits most '95 to '05 vehicles.
Two: It's for OBD-II cars only 1996+.1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
And that matters, why?Originally posted by HuskyI bet two things... One, it's for the Iron Head 3.4 pushrod.Originally posted by JimmyP70http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&N=115&y=13&s earchinresults=false&Ntt=NOS%2D05175NOS&x=17
I'd really like to know how the diagnostic software used in the PCM effects how Nitrous will be used on the engine.
I just looked up the kit in the NOS catalog, and it's a dry kit listed for "1994-present 3.4L, 3.8L V6".
Personally I would never go with any dry kit, a wet kit is the way to go if you want to be safe. Check out Nitrous Express. They have really nice kits. http://www.nitrousexpress.com/Pages/GMStage1.htm
The dry kit from Nitrous Oxide Systems increases the fuel pressure by increased vacuum to the fuel pressure regulator- it's safe.
The dry kit also prevents pooling of fuel in the intake.
I'm going with this kit. If it blows my engine I'll report it here.2001 Monte Carlo LS, 3400, DHP V1 PCM, Milzy Motorsports Fenderwell CAI, Dynomax exhaust, VDO Guages, DIY shift kit, Eibach Prokit springs, ADDCO swaybars, 18\" KMC wheels, SS appearance package.
Zex makes a good dry kit. i was going to get it A LONG time ago but my car got wrecked so i waited. Now turboing it. If you run a small shot dry you should be fine. wet kit is ideal but either way works.
SShane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
Now how is that going to increase the the flow of the injectors? The injector flow is controled by the PCM.Originally posted by JimmyP70The dry kit from Nitrous Oxide Systems increases the fuel pressure by increased vacuum to the fuel pressure regulator- it's safe.1999 Grand Prix SE 3100
1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
More pressure causes more fuel to pass threw the injector. Just like a Vortec FMU under boost.Originally posted by DarinNow how is that going to increase the the flow of the injectors? The injector flow is controled by the PCM.Originally posted by JimmyP70The dry kit from Nitrous Oxide Systems increases the fuel pressure by increased vacuum to the fuel pressure regulator- it's safe.
SShane "RedZMonte"
[QUOTE=JimmyP70]The dry kit from Nitrous Oxide Systems increases the fuel pressure by increased vacuum to the fuel pressure regulator- it's safe.
QUOTE] you do know that virtually every fuel injected cars FPR decreaces fuel pressure as you increase vaccum do counteract the effect of the fuel being "sucked" out of the injector to manitain a constant pressure. so increasing vaccum will lean you out and ull be buying a motor. dry kits are terrible on only work on a limited group of vehicles. Rule of thumb : you want ur nitrous like ur pussy...wet. honestly if ur gonna buy a dry kit take the money and wipe ur ass with it ull save ur motor. not puttuing anyone down here but i have installed around 30 kits and i will never touch a dry kit as i do not wanna be liable for some one losing a motor. if you want a nice clean install id say ZEX every thing is integrated into now box makes life so much easyer.1982 Twin Turbo Chevette:
2007: 3.2 Twin turbo, 309rwhp, 378 rwtq (detuned, stock botom end) 12.97@110mph
2008: 3.5 TwinTurbo...stay tuned
