Turbocharging Info
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Turbocharging Info
    All set.
    Can be locked.
  • gboogie99
    they still can't catch me
    • Nov 2005
    • 348
    sounds like you already got it figured out.
    • eliteweapons
      • Apr 2005
      • 185
      Don't you think you might want to consider remaping the timing for retarding under boost. It could save your pistons. Just adding fuel with an fmu is only part of the problem but the computer is going to drop that back and lean it out. Timing is also an issue.
      95 Beretta Z-26
      Don't need nitrous to go fast.
      Global peace through deadly force!
      • nocutt
        • 123
        I beg to differ...while I agree timing is an issue, this can be addressed with high oct. fuel and resisting going over a set pressure ratio...determined by CR, compressor efficiency etc, etc!!
        The PCM never 'sees' the change in fuel map because the change is happening at WOT (open loop)...
        hths
        3800 S3 intercooled turbo...
