3.1 Turbo GP Pistons
  • FlyNLoIMCA17
    • Jan 2006
    • 5
    Are the pistons in a 1989-90 grand prix 3.1 turbo different from the naturally aspirated 3.1's pistons?? Also are the head gaskets different??
    I am building a 3.1 turbo for my 85' S-10. I'm wanting to budget build it as much as I can, plus I'm only using a T-25 turbo and around 8-10 psi of boost. It will be intercooled and I was also thinking about using a methanol/water injection system and a CO2 intercooler spray bar. Also it will be carbureted most likely with a Demon blow-thru carb. Any suggestions are greatly appreciated. Also if anyone has anything to add from experience on the methanol/water injection or the intercooler spray bar please post!
    THANKS!!
    http://www.freewebs.com/flynloracing17
  • Syn
    The Master Piece
    • Oct 2005
    • 599
    Re: 3.1 Turbo GP Pistons
    THANKS!!
    with that low boost and small turbo i'd just keep the stock pistons, the tgp are suppose to be made stronger but theres alot of arguments.
    • FlyNLoIMCA17
      • Jan 2006
      • 5
      Thanks, what about the head gaskets? Are the TGP's different?? I was considering copper, but is it going to be neccesary with low boost like that? I thought about checking with Fel-Pro to see if they made any of their "black" head gaskets for this engine. I also race dirt track and build SBC racing engines and those are the gaskets we use, very durable. This will be my first 60 degree V6 performance build. I have built a few stock ones but none for performance so I'm not sure what all aftermarket parts are out there. I figure Fel-Pro would make me some if I called them. (for a slightly phenominal fee no doubt!)
      • mfewtrail
        ~600hp worth of 3.1's
        • 170
        The TGP pistons are the same as the NA and a standard Fel-Pro replacement headgasket(part # 9471PT) for the 3.1 will work fine. Plenty of TGP owners out there running Fel-Pro replacement headgaskets and 11psi of boost from the little T-25.
        Matt F.
        TGP 1/4 mile times
        http://photobucket.com/albums/y33/mfewtrail/
        1990 TGP Coupe VIN Database
        • Syn
          The Master Piece
          • Oct 2005
          • 599
          anything over 10 tho would be pushing it, copper is something you don't really want for a d/d either.
          pshh stock t-25
