2 bar map
  • StudlyCamaro
    • Nov 2003
    • 692
    2 bar map
    Originally posted by Syn
    Originally posted by StudlyCamaro
    its a top end stand alone engine management unit
    the 2 bar map is essential for high boost levels as a 1 bar map will not be able to read high pressures
    TTT for a good price
    totally incorrect information. don't post if you don't know
    a one bar map can't read above atomo pressure so thats why you have to use a 2-bar map. and that itself only reads up to certain psi above atom. pressure then you move onto a higher # map.
    how is anything you said different than what i said besides more detailed???? (i didnt want to whore norm's for sale thread so i started this thread)
    3.4L camaro some goodies
  • donk_316
    • Mar 2004
    • 427
    Looks like he didnt read what you typed and jumped to a conclusion. Your both right.
    I know i had to read your post twice just to make sure i wasnt reading it wrong.
    Its called "speed reading" but see what happens when you engage mouth before brain?
    1984 Indy Fiero 3.4L
    13.7 sec @ 98 mph
    *ALL THROTTLE AND NO BOTTLE*
    • Guest
      I guess it depends on your definition of "high boost".
      A 2 BAR MAP sensor will only read up to 14.7 PSIG. Some would call that high, while others such as myself do not.
      BTW a 2 BAR+ MAP sensor is not nessisary, which is what I think syn was getting at. I have ran a few turbo and supercharged vehicles utilizing a 1 BAR MAP. There is just now ignition or fuel trim/enrichment in proportion to boost pressure.
      • SHOoff
        • Jul 2005
        • 356
        Actually, your post does sound confusing. It almost makes it sound as the 2-bar is what you want for high boost and the 1 bar is fine as long as you're running low boost. I too considered it wrong by looking at it.
        Besides. I dont consider 15psi to be high boost. If you max out a 3-bar sensor (~29psi) then i'm sure that'll qualify as high.
        97 Cavalier RS
        3400, Isuzu MK7
        • donk_316
          • Mar 2004
          • 427
          Since when can you used a 1bar MAP for boost?!
          13.7 sec @ 98 mph
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            I don't think it's really something that should be done unless you are hacking along the job. I myself even went to II-Bar to make life easier, & I am not the motivated type.
            • Syn
              The Master Piece
              • Oct 2005
              • 599
              well i guess it depends on what your doing for fuel/spark that would depend on the map, if you use a rrfpr and ect and really no spark control you can keep the 1 bar map. but what i was saying is if the computer is going to be able to read boost you'll need a 2bar.
              i actually read the post and didn't jump to a conclusion
              raven hit it
              • 1988GTU
                LB62LHObbqftmfw
                • Nov 2005
                • 2475
                If you don't mess with the PCM/ECM, I would think you'd have issues running pump fuel around the 7PSI + range. ??? Even if you do use all those other bandaid parts.
                • StudlyCamaro
                  • Nov 2003
                  • 692
                  raven hit it
                  ahh, ok, just wanted to make sure that im on the right page (even if i suck with words)... i thought for a second i didnt know what a 2 bar map did
                  • Syn
                    The Master Piece
                    • Oct 2005
                    • 599
                    upgrade the fuel pump+rrfpr you don't reall need to mess with the ecm.but that setup is only good to maybe 10psi
                    StudlyCamaro ok glad you understand
                    • Fierobsessed
                      • Mar 2004
                      • 219
                      If you live at 6000'+ a 1 bar works pretty good up to a few PSI boost
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        True , but I didn't feel comfortable with it... Makes me sleep better at night knowing it's not throw together.
                        • matt_p
                          • Jun 2005
                          • 36
                          15 psi can be high boost. It depends on the engine. If you got a 427 V8, 7 PSI is damn high . If you got a 2.0L. 15, not so high.
                          1991 Cavalier VL Coupe 3400 5 speed
                          • Guest
                            Care to explain the logic in that? How does the displacement of the engine have any effect on what is considered high and low boost?
                            • Mars
                              • Apr 2004
                              • 826
                              LOL
