Questions for Anyone doing Boosted Gen2
  • EMX5636
    • Jan 2005
    • 50
    ok, here's the situation. I have a fiero with a peiced togther 2.8 in it. Using a gen2 bottom half, fiero heads, 3.4 camaro intake manifold and controlling it with a 7730 beretta ecu with tgp code. I have an issue with my wiring using the stock fiero harness swapped for DIS so I got a manual harness from a beretta in the junkyard. I grabbed the whole engine harness with relays, map and maf sensors, ecm, etc. I wanted to know if I should try and use the beretta code, and swap to a 2 bar map in the ecu, or keep using the tgp code and ditch the maf sensor? What are all you doing with the maf? Is anyone using it? thanks all
    Justin W
    1988 Fiero Formula - 3400sfi with an intercooled 60trim, Haltech, water/meth
    1990 Mitsu Eclipse GSX - parted out
    1991 Galant VR4 #108/2000 - Slammed sedan, built everything
    1995 Kawi Ninja zx7r
    1992 S10 4x4 - lowered/bagged, the dd
    2004 450R MX quad
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    FWIW:
    I have a Beretta that had the MAF. I really didn't like the maf so I switched to IAT along with the speed density upgrade.
    Turbocharging it didn't make a difference with or without it. I also "modified" my map sensor to fit the two bar TGP one.
