Update: DOHC 2.0L Pontiac "hybrid" turbo
  • pontiacjeff
    • Jun 2004
    • 147
    Just a little update for anypone who remembers the thread I wrote on DOHC turbo tuning (been two years...) on this DOHC turbo 2.0L "hybrid" Pontiac/Daewoo...
    (previous thread for reference http://60degreev6.com/showthread.php?t=27919 )
    With the new T3/T04E hybrid turbo and custom header, the engine made 307whp on 15psi. That would be 521whp on a 3.4! LOL!!!!!!!!!!! I estimate 375-380hp at the crank. I am still running the intake cam retarded one full tooth (15deg retarded) and the exh cam stock. The new turbo is real big for the 2L (it's one I bought for my 3400!). It has a T3 .84 a/r turbine housing with a custom GT35 wheel. I want to advance the exh cam to help it boost quicker (it doesn't reach full boost 'til 4200 from a 4th gear 2000rpm start), but I am limited to one full tooth and afraid of valve contact at the end of the exh stroke. I have sourced-out a set of adj cam gears for this engine from the UK, so that's the next step.
    Read the first post in the old thread above for the background. There are HUGE gains for the 3.4DOHC engine if running a turbo that will make the "lazy" cammer a real torque monster. An appropriately sized turbo will only enhance the naturally aspirated tq curve of the 3400. With cam timing changes, you can get the advantage of fast boost offered by a too-small turbo AND the high end charge of a properly sized turbo!
    Jeff Ianitello
    Engineered Performance
    Atlanta, GA.
  • Guest
    Thats not entirely true. The t3/4E wouldn't be able to support 521 whp especially at 15 psi. Turbo isn't big enough. Can't flow the air to make that sort of power.
    But other then that it looks good. Def good power there. Nice Job. You still talk with Travis?
    • pontiacjeff
      • Jun 2004
      • 147
      Apples-to-apples... this turbo is big for the 2.0L. A big turbo for the 3.4DOHC would be a 60-1 or 62-1. A 62-1, P-trim would easily flow enough air for 600hp, but you still have to boost it up higher than 15psi.
      Think about this: the stock 2.0 DOHC Daewoo is rated at 130hp and probably makes about 110whp. On 15psi, in theory, I should be making 220whp. But that turbo is flowing alot more than double the stock airflow at 15psi. Likewise the stock hp rating on the 3.4DOHC is 210-215. They usually make about 175whp. Most of the turbo guys are making about 325-375 on 10-12psi. That is also "above the curve" for theoretical estimates. I think the 3.4DOHC can easily make 500whp, but it might take 18-20psi to do it. One 3800 Series II guy I know is making 459whp on 19psi with bone-stock engine and it's two-valve heads. Figure that engine starts out around the same with 205hp rating. But the twin cams really excel in the airflow dept! Given the airflow numbers available on this site, I can see the 3400DOHC turbo making 500whp.
      I don;t know when I'll get to it, but I still plan to turbo my '96 3400DOHC in my '90 McLaren Turbo Grand Prix.
      Jeff Ianitello
      Atlanta, GA.
