Rebuilt 3.4 DOHC
  • d.o.h.c
    • Jun 2004
    • 981
    Rebuilt 3.4 DOHC
    I have a 95 3.4 DOHC that my father and I rebuilt. It currently has about 1000 miles on it. It runs very stong and does NOT burn/leak any oil. The motor was completly torn down and rebuilt. WE bought the motor from e-bay and was told that it turned over but did not run. Well we got it and someone droped a nut down the cyclinder. So we rebulit it. It was honed, new rings, everything. By the way the motor only had 33,000 miles on it. I have around $3200 in it and would like to get around $1500
  • d.o.h.c
    • Jun 2004
    • 981
    after doing some research it look like $1000 would be a good deal.
    • zofo61
      Banned
      • Oct 2005
      • 436
      I have a friend that needs this.....where are you?
      • d.o.h.c
        • Jun 2004
        • 981
        Florida, Lake Mary
        • d.o.h.c
          • Jun 2004
          • 981
          Bump
          • Sourmug
            • Aug 2005
            • 52
            Hi:
            Do you have more details/info an what all was done to it? Will you ship to Canda?
            Thanks
            Nolan
            • d.o.h.c
              • Jun 2004
              • 981
              Sure. The engine was bought from e-bay and was the seller told us that it turned over but it didn't. So we took the hole engine apart and found a screw in it. So we had the block honed, the piston that was ruined replaced. it has new rings, new bearings, new seals, all felpro gaskets, valve job, crank was miked and check for cracks and it was polished. the bolck was boiled and painted. The oil pan was brand new when we got it so that was not replaced.The timing belt and all components were replaced and timed. the motor runs strong and does not leak any oil. I will ship it to canada but it might be expensive. Do you have a shipping company.
              • tobz
                • Apr 2007
                • 6
                Could you get me some dimensions of the motor? I have a 1996 Cutlass Supreme with the 3.1L SOHC. I am interested in swapping in this motor.
                • Sourmug
                  • Aug 2005
                  • 52
                  d.o.h.c:
                  PM sent.
                  Thanks
                  Nolan
                  • d.o.h.c
                    • Jun 2004
                    • 981
                    Yeah this motor should swap right in no problems. Might want to check the board though
                    • Sourmug
                      • Aug 2005
                      • 52
                      Hi:
                      Response to your response sent.
                      Nolan
                      • MONICAZ34
                        • 111
                        See your PM, DOHC
                        • d.o.h.c
                          • Jun 2004
                          • 981
                          Motor is going on ebay
                          • d.o.h.c
                            • Jun 2004
                            • 981
                            lowering my price to $850
