f/s**LOOK** 90% complete lq1 engine w/extra
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    i am thinking of selling my "backup" engine. it is a mildly modded lq1 in great shape.
    runs strong, good compression, good power. it is the original engine that came out of my 94 gtp. i personally put about 10k on it be4 swapping in a completely built engine and decided to keep this one as a contingency. i am in a space crunch again and could also use some dough for more R&D as well.
    but do not get confused, i am not desperate or anything so no lowball offers, you will be wasting your time if u do. next i will not part it, so do not ask.
    now for the good stuff: it comes with almost everything. i will include one of my good spare PS pumps, a spare set of coilpacks and ign module, a 96 bracket, the intake has been modded for a tb coolant bypass as well as an egr delete, i'll throw in an alt, i also installed a set of 96-97 valve covers, included is a good stock hm-284 clutch pressure plate and flywheel and/or a good 4t60e with flexplate that i cannot seem to give away, an untested a/c compressor(i think it works but cannot say for sure), crosspipe, serpentine belt if i can find it and plugs wit about 40% life left.
    the topend was rebuilt by the previous owner including new timing belt stuff(then, it has a few miles on it now but still has about 66% life left on them) and the heads were cleaned up with new valve seals in them. also i think by looking at the flats that he MIGHT have done a cam timing change but cannot say for sure. also you'll need not worry about the dist plug, it didn't leak to begin with but i still put a bead of liquid gasket on the top so it should never leak for a LOOOONG time.
    what it needs: does not have plug wires, a knock sensor(sorry i needed one for my other engine ), a serpentine tensioner pulley(just the pulley the arm is there and works fine, i needed the bearing out of the pulley for my billet one) intake gaskets as i had to pull the intake to pull the engine, it needs a throwout bearing if u go that route, it needs a front exhaust manifold and gaskets for it.
    depending on your needs, if you plan on doing a 96-97 intake swap later i will leave the coilpack bracket stock or if u want i can modify the bracket to work with the intake on there. your choice.
    lastly, regardless of what parts you do not want the price stays the same, your savings will be in shipping.
    i am looking to get $500 plus shipping which i think is a modest price for what you are getting. i'll post up pics if there is any interest as lq1's do not appear to be hot on the market.
    p.s. for $650 i'll throw in a 99% complete 96-97 intake conversion. while the egr bypass is on the exhaust manifold, i do not have a plate for the intake but i can include a simple cap to plug the one hole. this will be in addition to the 94 intake you already get. this offer only applies to this purchase, cannot be purchased seperately or substituted for the intake that comes with the engine.
  • d.o.h.c
    • Jun 2004
    • 981
    man thats a good price. But when you do that people put there standard amount lower and lower and lower. thats why w-body parts are so cheap. Anyways who cares I hope you get it, I am selling my motor now as well.
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      hey thx and you are right but i kinda have to offset the price lower to make up for the price of shipping so the engine can be in a price range attainable to more members.
      also by offering a good engine for a good price will be like an investment in the community for b/c it will be 1 more lq1 in a car and that person may be saved from the 90 degree v6 tyranny.
      if some1 were to pick it up however that is where it becomes a sweet deal if they were close.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        here are some misc pix. and you do not get the billet serpentine tensioner. as you can see this is stored inside away from the elements.
        i have more parts that are not pictured but i am not digging all that stuff out until i get some serious inquiries.
        oh btw another upgrade option: for $750 i'll throw in a set of 97 cam carriers w/lifters on top of the 96 intake. the 97 cam carriers use 33mm lifters compared to the larger and heavier 35mm lifters in the 91-96 year cam carriers. also some of you prefer the 91-95 cams b/c it is said they are more aggressive than the 96-97 cams. the 91-95 cams will slide into the 97 carriers np, so you can have your cake and eat it too .
        • toms92gp
          • Apr 2007
          • 49
          if i had the extra cash and didn't have an extra engine already i would be all over it, especially since it would only take me about 2 hrs to get to your place.
          http://www.cardomain.com/id/toms92gp
          http://www.nightrydas.com/theprix.htm
          • cheezx
            • Mar 2007
            • 9
            Would you be willing to let the 96-97 intake conversion go separately? It would be perfect with the newer heads (if you ever get me a shipping quote, LOL).
            • dohcfiend
              King Chalupa
              • Jan 2004
              • 2351
              damn it. forgot all about the quote. i'll get on it. i will have to decline on the intakes for the moment as there is some1 interested in everything. if it falls through, i'll consider it.
              • Sourmug
                • Aug 2005
                • 52
                Bobby:
                Were you going to get a price on shipping for this?
                Thanks
                Nolan
                • dohcfiend
                  King Chalupa
                  • Jan 2004
                  • 2351
                  i was just going to go online and get a quote from whoever just as a ballpark but if u have some1 in mind, i'll be happy to contact them.
