Third Gen turbo pipes
I am changing my setup and might be interested in selling some stuff...
These parts are on a 3rd gen Firebird.
1. Modified stock y-pipe routed under the k member to the turbo that will sit in front of the water pump. ($75 + shipping)
2. Down pipe that also goes under the k to the stock exhaust location (it is clamped now, so you can use it w/o welding) with mounting location for 38mm wastegate and has two o2 bungs (one for WB and the other for NB sensors) and will include a plug for the one not being used. ($75 + shipping)
3. If the price is right, I will sell the charge pipes and intercooler (including the connectors). They are on a Firebird and will fit a Camaro if the battery is on the driver's side (will modify to fit pass side for a small fee). ($200 as is or $230 modified to fit pass battery + shipping)
I will take $400 + shipping if you want it ALL and will throw in the oil pan with -10an bung welded in it for oil return
To finish the kit, you will need a turbo, wastegate, oil lines and BOV. If you bought the same turbo, etc as me you will need aprox another $400 in parts to finish the kit.
If you buy everything, there is no need for welding since the downpipe can be clamped to the stock exhaust (clamp included). The only thing needed to be done to the car is a 3" hole drilled in the location in the pics and two 3" hole drilled into the air dam.
Here are some photos as the system was being built. Since the time of the pics, the hot pipes have been painted with high temp flat black...
