FS: Eaton Magnacharger
  • bballr4567
    • Jul 2007
    • 2
    I have had this kit for almost 4 months with the promise of getting it installed and went about it yesterday only to have a few problems with the fit. I dont know about other years but on mine the thermostat housing tube is different and actually hits the SC unit. Plus with me deploying in 3 months to Iraq for 15 months I figured that instead of really making it fit and making it run great Id give someone else the enjoyment of all that.
    Onto the kit, its a Gen 3 EM and one of 18 made. Everything in the pics (yes they are not mine but are the EXACT same as its same kit) is included. Also included are some hoses and the belt that is needed to make the SC work. It has some chips in the paint. Also the mounting bracket was ground down on some to try to fix the problem.
    Just FYI, the problem with it fitting probably isn't because of a difference in the thermostat housing, but because that kit is one of the prototype models. You can tell by the straight instead of snaking intake tube (meant to go around the battery on the later design) as well as the different outlet and the external bypass valve on the gen3 blower instead of the internal bypass with the actuator on the other side like in the gen4 blower. That kit they only made like 4 of and that the one used in the SC/T concept cars.
    Tstat tube can be bought from metalmanfab.com for cheap I have been told.
    This is actually on the bottom side of the unit.
    Im looking to get $2500 for everything seen above.
    Im am well know on GAOC and GAGT forums. Im sure some on here will recognize the user name. Thanks for reading.
    Josh
  • bballr4567
    • Jul 2007
    • 2
    TTT
    This will be something awesome for you serious serious guys.
    • Cliff8928
      • 532
      There's been no update, do you still have this for sale?
      Cliff Scott
      89 BerettaGT
      04 AleroGX
      • black05gt
        Damn Yankee
        • 74
        My understanding is that Josh (bballr4567) sold this SC some time ago - and he's been deployed to Iraq, so don't know if/when he can respond personally.
        ported 3500 heads, LIM, plenum, 28# TB FI's, TCE 65 mm TB, MPR CAI, F&R strut bars, F&R sway bars, Eibach springs, KYB GR2's, TOG headers, hi-flow cat, Borla muffler and tips, LC-1 WBO2, DHP PT
        • blkalero
          • Oct 2004
          • 42
          did this unit used to be installed on a malibu in phoenix az?
          • z34choppin
            • Nov 2008
            • 3
            What Motor Does That Fit?
              • 9190
              I hope you aren't looking to buy it, as this thread is over a year old, and I'm pretty sure this SC has found at least 1 (if not 2) new owner.
              • black05gt
                Damn Yankee
                • 74
                Yup, one of them being me :-)
                • Nick-G
                  11's or Bust...
                  • Feb 2008
                  • 224
                  I have one for sale if your looking for one.
                  BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
