*FS: Turbo, FMU, Misc turbo stuff.
  • FallenZ24
    • Nov 2005
    • 178
    Things FS:
    Rebuilt CT26 turbo from 87 Toyota Supra. It was on my 2.8L Fiero and spooled great. Max boost of 10psi by 3000 rpms. A little big for the fiero but it should work great with a 3.1/3100/3400. $250
    SMIC from a Nissan Skyline. It was also on the Fiero and worked great. It is used though. It could use some cleaning up. $20
    Cartech/Begi 2025 FMU. Works great to increase fuel pressure with each pound of boost. I saw pressure in excess of 90psi @ 10psi of boost. It is capable of going higher or lower depending how you adjust it. Comes with mounting plate, check valve and instructions. $250 shipped
    Freshly Resurface OEM Flywheel. Fits 2.8/3.1/3x00 engines with the Getrag 5-speed. It came out of my 90Z24. Im sure there are other cars it fits also. $50
    All prices are negotiable. Im not giving these parts away though. Feel free to ask any questions you want. Hopefully I can sell these parts so I can start tuning the Z24.
    -Joseph
  • FallenZ24
    • Nov 2005
    • 178
    I don't know the a/r of the housings but they arent tiny. I can get you wheel sizes.
    Comp. In - 1.75"
    Comp. EX - 2.559" = 47trim wheel
    Turbine Minor - 1.97"
    Turbine Major - 2.36" = 70trim wheel
    For more pics of the ct26 turbos. It's not mine but will give you a good idea of what they look like. I'll try to get some more pics of my turbo.
    • Guest
      How is 10 psi by 3k rpm too big of a turbo for a 2.8?
