3.4 iron head goodies
  • merlot566jka
    • Nov 2006
    • 570
    everything is for sale! going with the 3500, have to sell al the old stuff....
    trueleo short runner intake, painted red, will strip paint before shipping if need be. its ported to the max dia of the ram-pipe (63.5mm)....$350 with 65mm tb $400
    two mustang 65mm tbs, one is currently bolted to the trueleo and will only work on that manifold. $50 each
    electromotive iac adaptor, comes with iac installed, allows you to use 65mm tb on almost any vehicle...$85
    comp roller tipped rockers, 1.6 ratio, less than 3000 miles on them, $100
    SIvalves.com's stainless steel valves, swirl polished. they measure bigger than the stock valves on the head of the valve, 1.8 and 1.6 intake and exhaust, $120
    crane cams h-11 tool springs pn 99846, good for .6 inch of lift, $120 (i payed $220!)
    crane cams valve spring retainers and +.050 locks.....$70
    two 3.4 lower intake manifolds...$35 each (no csi port)
    modified fuel rail, no csi port, $25
    brand new lifters(12), sealed power, $60
    crane h-272-2 camshaft, 3000 miles, great shape, USE NEW LIFTERS, $100
    clevite pushrods, stock length, $35
    3.4 iron head short block, zero decked, bored .020 over, 3000 miles, high volume oil pump, oil pan, timing cover, water pump, timing chain and gears, PICK UP ONLY, $400
    2 distributor dummy shafts, for dis conversion, $25 each
    7730 ecm from a 91 camaro with prom (has to be programed before you can use it on your fiero!!)...$80
    dis coil pack with icm (3 sets of coils with icm for dis conversion) with connectors for conversion...$70
    crx cold air intake, modified to fit fiero, with generic blue filter, $15
    pictures on request, pay pal only, i ship when money hits my pay pal. all prices are WITHOUT SHIPPING!
    post up dibs along with a email to me if your interested. thank you! (merlot566jka@yahoo.com )
    2012 Chevy Sonic Turbo 6spd
  • merlot566jka
    • Nov 2006
    • 570
    lifters and valves pending
    • 2.8RS
      Cone Murdurer
      • 196
      If you were alot closer I would love that short block for my Camaro to replace the tired 2.8.
      00 Grand Prix GTP Daytona
      • merlot566jka
        • Nov 2006
        • 570
        where are you?
          Live life 3.7mi at a time
          • 4555
          Originally posted by merlot566jka View Post
          where are you?
          We're in a place that's sunny year-round 2.8 is a little North of me, though.
          Actually I had a 3.4 shipped from NY because it was a known running car (and cheap), it came to just over $200 for commercial to commercial freight with Con-Way.
          • 2.8RS
            Cone Murdurer
            • 196
            where are you?
            Panhandle of FL. I guess that I need to put my location in.
            • merlot566jka
              • Nov 2006
              • 570
              i wouldnt even know how to get the engine ready to ship, where to take it to so it can be shipped...etc.
              maybe if i knew the process it wouldnt be so daunting.
              its on a few hours trip if you come get it. i used to drive from washington state to oklahoma and virginia to oklahoma all the time when i was in the navy....its actually kinda fun. it may even be cheaper than shipping. ill throw in a case of beer if you drive up...ill even help you drink it. but you WILL NOT drive after drinking. i cannot allow that!
              • 2.8RS
                Cone Murdurer
                • 196
                As much as I would love to get that motor I won't drive from here. I can get a stock one that needs rebuilding here in FL for $400-$500 hopefully. If you shipped it may be cheaper to get that instead of having to pay for parts for a rebuild. Maybe I can rent a U-haul when school gets out. That will give me time to save up a little and plenty of driving time. Maybe we can work something out.
                  • 4555
                  It's not that bad to ship an engine. Get a small pallette, and strap it on, go to your nearest Con-Way (they sub from UPS) and it's a done deal.
                  There is no way with gas prices - that it would be cheaper to drive.
                  Put it in a shipping calculator, shortblock and pallette weighed 220lbs. (with timing cover and oil pan).
                  • 2.8RS
                    Cone Murdurer
                    • 196
                    I just looked up the drive on mapquest and its probably around 1100 miles to drive over there and then another 1100 to drive back. After gas, food, hotel, I could have bought another motor.
                    • merlot566jka
                      • Nov 2006
                      • 570
                      eh, yea thats true. ill see if i can contact a con-way tomorrow and see what the cost would be to ship it.
                      • 2.8RS
                        Cone Murdurer
                        • 196
                        Thanks. Zip is 32317 since they will probably want to know.
                        • megafreakindeth
                          • Feb 2007
                          • 22
                          i pm'd you as well but im interested in the ecm stuff. i wanna do a 7730 ecm swap so if you have the pigtial for the egr, evap, and ecm ill take all that. pm or e-mail me, e-mail preferred.
                          bummer on the engine my stock 3.4 with trueleo intake and exhaust got 137hp(5spd, gm 260h cam) and now ive got dohc pistons a 5 angle job and minor porting(the easy stuff). what tb were u using? stock? ive got a 60mm on now.
