Just like it says. I also have the exhaust manifolds with o2's, harness, oil pan, coil packs and fuel rail -everything is up for grabs, just let me know what you need and we'll work something out. 22k miles on it.
Parting out (or complete) 3500 shortblock
Tags: None
Why the engine harness? Going to put the engine in a go-cart?
Shouldn't be needed for engine swaps.
I could possibly use the oil pan, and the 3500 short block I have threw a rod through the pan...-Brad-
Oil pan, you can have for shipping. I'll take a pic, but the fron pass side corner had a bolt in it, and when they put it on the crate, brok the hole. Can TIG it shut to re-tap, but don't know if it's even needed for your application. Doesn't penitrate through.Originally posted by bszopi View PostI could possibly use the oil pan, and the 3500 short block I have threw a rod through the pan...
All sensors are there except fo the ones in the head (and no injectors).Originally posted by El_Diablo View Postfull engine harness? might be interested....
Herness complete for $50 + shipping including whatever sensors you need.Originally posted by El_Diablo View Postyes, sensors aren't absolutly needed but it would be nice... whatever works for you though
It's not dissasembled yet either, were you still looking for oil squirters?
The squrters spit oil on the back of the piston. There are many mfgrs doing it now, make the pistons much cooler.Originally posted by dohcfiend View Posti have to ask a couple questions.
1st of all why are these squirters so desirable?
second perhaps you could pm me a couple quotes? 1 for rods and crank 2nd quote for just crank.
