WTB 3400 uper and lower intake
  • jdog_kustoms
    • Dec 2007
    • 62
    looking for a stock 3400 or 3100 "big bore" intake
  • Barry
    95 Beretta LG8 Action
    • Aug 2007
    • 269
    How much are you looking to spend. I have a upper and lower intake off a 99 3100.
    95 Beretta- Lg8 Daily Driver
    • guest3224
      • Nov 2007
      • 8
      I've got a upper and lower from an 05 3400 motor, fuel rail and injectors.
      $150 for everything shipped in the U.S.
      G6 GTP 3900 6spd Coupe
      • jdog_kustoms
        • Dec 2007
        • 62
        intakes
        are the intakes stock or worked done to them
        • guest3224
          • Nov 2007
          • 8
          If you're asking me well NO, they are stock no work done to them.
          STOCK Upper/Lower intakes, fuel rail w/injectors, and the TB.
          I was going to do the 3400 top end swap on a old Beretta I had but change of plans. Sold heads locally awhile back.
          • Barry
            • Aug 2007
            • 269
            Mine are stock. I painted the upper intake red, but I cant strip that off for you very easily.
            Shoot me an offer of what there worth to you.
            • Guest
              I have a large bore 3400 upper and a large bore lower.
              THe lower is brand new never installed but did do a bit of gasket matching on. The upper is used but good condition. Says 3400 on it
              The upper I might have touched up a bit to clean up the flash, and the lower I gasket matched the upper part of the middle intake where it meets the upper intake.
              I also have a fuel rail too if needed. I can take pics of everything
              Shoot me an offer.
              Shaun41178@hotmail.com
                Are those 99 3100 intakes the big bore ones? I assume so just curious as it seems the big bore 3100 in 99 is kind of rare.
                • Barry
                  • Aug 2007
                  • 269
                  I never compared it to my current 95 topend. But its off a 99 and has the smooth top with the raised numbers.
                  How can I confirm that its a big port?
