3100 Pistons & Connecting Rod
  • 94GPGTP
    95 Grand Prix GTP
    • Apr 2007
    • 593
    I need 2 pistons and connecting rods on them.. i pressed used rods on mine and they are on backwards and dont wanna risk breaking piston trying to turn the rods over.... its a pita.... lmk thanks
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    Live life 3.7mi at a time
    • 4555
    What did you use to press them on? Proper tooling should be able to turn them around without damage. A machine shop might charge you like $10/ea.
    • 94GPGTP
      95 Grand Prix GTP
      • Apr 2007
      • 593
      we used sockets to press on the pin... and used washers to support the rod, and used some square stock to support the piston..
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
      • TDIXON
        Red Monster...
        • Dec 2007
        • 102
        put them in the oven for 10 to 20 min and the pins may come back out easier. idk but just a thought.
        1992 Buick Skylark 2.3L 1996 GrandAm 3100 SFI 1996 Ford E150 Conversion 5.8L
          • 4555
          Not really. The aluminum expands faster than the steel and will cause more pressure on the pin itself - remember the pin is surrounded by aluminum.
          Cooling the pins or heating the rods make a faster press-on, but pressing off makes it difficlut since the metals are touching and transfer heat.
          • TDIXON
            Red Monster...
            • Dec 2007
            • 102
            i wasnt for sure .
