Looking to buy an UIM or LIM from a 99+ 3400 Grand Am se or gt for cheap..... Hit me up if you have either. THANKS !!
WTB: 3400 UIM or LIM.
Tags: None
How much would you consider cheap?
ive got a lowerintake manifold thats got a '00 numbers marked on it i resealed the crossover pipe as well...make me an offer00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
