LQ1, L67, and big block parts
  • latemodelnewbee
    • Jun 2007
    • 227
    LQ1
    92 heads and cam carrier $150
    92 intake manifold with fuel rail and injectors $75
    92exhaust manifolds with AIR pump ports (from 5 speed car) $20
    GM power steering pump $20
    coil with mounting bracket $15
    L67
    2 sets of injectors with clips $60 per set
    eaton M90 blower $250
    3 brand new ACDelco injectors $75 (retail price from the dealership $147.99 each)
    Big Block Chevy
    Krptonite billet steel crank 4" stroke $500
    turbo 400 transmisson $150
    everything came ourt running perferctly fine execpt for the big block crank and that just a little machining and to be balanced to your specs. The prices are all O.B.O.
    More parts to come
    68 El camino 454 speed muncie 3.90 posi 12 bolt,
    80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
    60 Impala 2 door hardtop L79-327 T56 4.11 posi.
    83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
    91 Z34 now has a hm284. and belly pan in the works
  • latemodelnewbee
    • Jun 2007
    • 227
    prices aren't set in stone just trying to make room
    • latemodelnewbee
      • Jun 2007
      • 227
      I would consider trade for parts. I'm looking for 96-97 head 94-96 cam carrier with cams
      • latemodelnewbee
        • Jun 2007
        • 227
        bump
