96 3.4 DOHC Cam Gears
  • vmaxed69
    • Mar 2009
    • 8
    Wanted 96 3.4 DOHC Cam Gears
    I busted 2 cam gears on my 96 MC. I have not been able to locate any around Ft. Worth any info would be appreciated.
    Thanks, Clint
  • bve32k
    3.4 DOHC FTW
    • Jun 2005
    • 475
    How did they break?
    • vmaxed69
      • Mar 2009
      • 8
      They were way to tight so I twisted my holding tool. Then did what any genious would do & used a pipe wrench before I found out the pulleys were discontinued.
      • Dave96z34
        • Apr 2005
        • 624
        Also under that bolt is a typ of lock washer What you should had done is turned the cam 90deg and put an adjustable wrench on the cam.
        • Sonyman
          • Jan 2008
          • 160
          hey im in grapevine,tx. i think a gotta couple foe ya. holla back
          • vmaxed69
            • Mar 2009
            • 8
            Hi Sonyman I sent you an email but not sure if you got it it doesn't show up on my sent folder.
            Thanks, Clint
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              I have a couple cogs currently. PM sent.
