3400 High LB/hr injectors
    I do have a tester, it just has a very short hose... and my long one doesn't go over 50psi.... so its hard to test while in the car... I'll try to figure something out, I have a bunch of nitrous lines and such.
    I'm mostly concerned about the fuel pressure due to longevity of the injectors, Granted I have not once gone lean either and I'll have the wet shot for the nitrous so thats not a big worry, but I hate to run out of injector later....
    92cavquest thanks for the offer, I'll let you know how I make out... I have my harness setup with 2005 Multec 2 plugs, NOT the 3500 style harness... since those injectors are too short to begin with. I have the long pencil ones from the 05 Trailblazer. Bottom line if the pressure is supposed to be 61, I'm way below right now and I need to get it there for those to be working right and efficent.
      well adjusted pressure and now my trims are a -5% so thats a good sign that going from 55psi to 63 gave my injectors more flow... So i'll be tweaking my file to adjust for the extra fuel and also see what my WOT IPW's and A/F are now.
      • Chris88CL
        Moderator
        • 212
        I have some 36's from a SC3800 I'd let go cheap.
