Sensor Pigtails
    For Sale : Sensor Pigtails
    since i don't need the engine harness for the 92 GP anymore i cut it up into usable lengths. i tried to get at least a foot of wiring for each one, some got more, some i had to give it 2", then solder and heatshrink on an extension of wire. most if not all of the sensor connections are here, and i also have a IAT sensor. the only things i can think of that are missing is that i only have 3 or 4 fuel injector connectors, 2 of them i had to extend, and i'm not sure where the third and possibly fourth one is at the moment...
    price: IDK a dollar each + shipping, OBO?
    i'm not really looking to make money off of them, but i don't need them and i'm sure someone else does...
  • jmgtp
    • 1219
    I need the connectors for IAC, MAP and Charcoal Canister.
    Give me a total cost shipped to 06473. Paypal work?
    Thanks,
    John
    1994 Corvette
    LT1/ZF6
    2006 Dodge Dakota 4x4
    3.7/42RLE
      IAC
      MAP
      Canister Purge
      do all of these look right?
      and i can't do paypal, sorry, my account is locked from someone trying to get into it and i can't get ahold of the info necessary to unlock it.
      • jmgtp
        • 1219
        yes, those look correct. I'm assuming none of the ones your are selling are broken? The securing tabs on mine have snapped off.
        I can send you a check, PM me your info and price.
        1994 Corvette
        LT1/ZF6
        3.7/42RLE
          well count out the MAP sensor and the cannister purge
          MAP: tab is broken off
          Cannister: can't find it.
          the IAC still has a good tab and seal but i'll have to extend the wiring.
          • jmgtp
            • 1219
            ok, nevermind then.
            1994 Corvette
            LT1/ZF6
            3.7/42RLE
              The MAP's always break off. The green plastic is brittle compared to the black I guess.
              • tkoforpresident
                Max
                • Feb 2009
                • 710
                do you have anything for the pre cat o2 sensor??
                93 Firebird 3.4
                • neo71665
                  its this big
                  • Oct 2005
                  • 361
                  Did those have the 3 wire heated o2 sensors in them? If so I'll send ya $5 for the plug and that should cover all shipping.
                  87 3.4 4x4 blazer
                    GRAVE DIGGERS!
                    pre-cat O2? i can't think of any 60V6 applications that were OBD1/1.5 that actually used a post-cat sensor... if you're talking about the 'bird, i think that used just regular 1 wire O2s? i'll have to look to see if i still have it...
                    and no, the early LQ1s did not have a heated O2, and i think we went directly from a 1 wire to a 4 wire... though the actual connector may be a standard one, i really don't know.
