1995 Monte Carlo 3.4 DOHC Part Out
  • Sidewinder
    • May 2006
    • 240
    I'm starting to tear apart the monte carlo Z34 I bought awhile ago for parts and I was wondering if anyone needed engine parts or anything before it goes to the junkyard. I'm going to go out today and get some better pictures of it, but here is some for the interim:
  • hookdonspeed
    • Jun 2007
    • 322
    hrm does the 3.4dohc use the normal 2bolt throttlebody setup? ii may be interested.
    edit: did some searching, its 54mm, perfect for what i need.
    if it has the standard 2bolt, or the 3500style 4bolt, lemme know howmuch shipped to 20707
    • bve32k
      3.4 DOHC FTW
      • Jun 2005
      • 475
      No, the 91 - 95 3.4 DOHC's do not use the standard bolt on throttle body. Only 96 GP's. As you can see in the pic it does not come apart.
      • hookdonspeed
        • Jun 2007
        • 322
        ah foey, oh well, was worth a shot.
        • jmgtp
          • 1219
          I need the rear cam/valve cover.
          1994 Corvette
          LT1/ZF6
          2006 Dodge Dakota 4x4
          3.7/42RLE
          • Sidewinder
            • May 2006
            • 240
            Yeah was gunna say it looked like one piece. Sorry mate.
            I can def. get that for you, it may take a bit though because I'll need to get the time to get at it.
            • jmgtp
              • 1219
              its only a couple plenum bolts away :P
              Let me know a total cost shipped to 06473 before you go through the trouble.
              1994 Corvette
              LT1/ZF6
              3.7/42RLE
              • jmgtp
                • 1219
                If you're willing to cut the wire harness I also need the connectors for the MAP, IAC and Charcoal Canister. I'd want a few inches lead of wire on each if possible. Let me know on those as well.
                1994 Corvette
                LT1/ZF6
                3.7/42RLE
                • Sidewinder
                  • May 2006
                  • 240
                  Sent you a pm.
                  • RedStrega
                    • Jan 2006
                    • 14
                    bolts needed
                    I need those in red circle
                    • Sidewinder
                      • May 2006
                      • 240
                      I will get those as soon as possible, won't be until next week though I'll be working like MAD this weekend.
                      • RedStrega
                        • Jan 2006
                        • 14
                        No problem, let me know
                        • Fieroking
                          • Aug 2007
                          • 20
                          Need injectors
                          How much for the fuel injectors?
                          Joe Sokol
